Like Tree447Likes
Tamiya M-08
Old 09-09-2021, 03:04 AM
  #496
ruebiracer's Avatar
Originally Posted by cementsurfer86
ruebiracer, I'm glad it's working well for you!
Currently, I have the aluminum steering bridge with a 1.5mm spacer behind the ball stud. Hope this helps!
I'll post up my Regionals/current setup here in a bit. Not much has changed, but just a couple tweaks to the rear shock oil, etc.
Thank you so much Jesse for revealing your steering setup, too!
Just grabbed your update from the regionals, I hope Ive time to test soon!
Kind regards and keep up the good work,
Matthias
Raman and cementsurfer86 like this.
ruebiracer is offline
Old 09-09-2021, 03:08 AM
  #497
ruebiracer's Avatar
What I forgot to ask:
You write "Droop - measured over ride height" is clear for me, but what you note in the rebound stroke is e.g. 7mms. But his seems a quite high droop value? Maybe its just this way, or am I missing something here?
Old 09-09-2021, 03:11 AM
  #498
ruebiracer's Avatar
And another question regarding the shocks: With black pistons, you mean the ones coming with the std. V-parts? Not the white Teflon nor the black POM version from TRF 419?
Old 09-09-2021, 12:27 PM
  #499
cementsurfer86's Avatar
7mm is the total ride height when the car is fully drooped-out.
So for example, say I have 5.4mm of ride height... With a 7mm ride height at full droop, I would be running approximately 1.6mm of droop.
It's an easy way I've found to give me a quick reading for droop that I can check easily when testing and making constant changes, rather than removing wheels and using droop blocks, etc..
As for the black pistons, yes those are the standard black plastic pistons found on the V-parts tree. I've found these to be just a hair smaller in diameter over the white delrin pistons, which reduces drag in the body itself. You'll also notice that the black pistons have a slight "flat spot" on one side. In my testing, this gives the shock less "pack" and allows the shock to cycle oil easier throughout the shock stroke, which gives a more planted feel on the m-chassis cars. It tends to reduce the bouncing effect that can happen with these smaller cars, especially outdoors on asphalt.
I would try both and see what you think, but from my experience with my own cars, I'm able to fine-tune the feel of the shock package better when using the black pistons.
Hope this helps!
ruebiracer likes this.
cementsurfer86 is offline
Old 09-09-2021, 03:26 PM
  #500
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
One more go at TCS this weekend with the M08. I may give in and join the masses on the dark side.... the M07.
Dan is offline
Old 09-09-2021, 07:21 PM
  #501
Raman's Avatar
Trader Rating: 94 (100%+)
Come on Dan, wheres the challenge in joining the herd. You can do it.
Raman is offline
Old 09-09-2021, 10:04 PM
  #502
ruebiracer's Avatar
Hope this helps!
Thank you Jesse for the explanations again! Now its crystal clear, how you measure your car and what is the background on the shock pistons. Also like your method. Still seems weird to me to put a M-chassis on droop blocks with the rebound stroke gauges likea touring car. And totally true with the shock pistons. The TRF pistons are way more tight with the missing flat spot and smaller bore holes. So if your car runs superb with CVA dampers, its not easy to switch to TRF dampers and create the same amount of damping / pack. Probably, that was also the reason Tamiya changed the bore holes in the TRF shocks of the M06 R version. They increased the 3 hole piston to 1,3mm holes on the rear axle for less pack. I found this setup to be really good aon the M06 and always sticked to it...
On my M08, I still have the CVAs at the moment, but plan to switch to TRFs in the future.
Kind regards,
Matthias
Old 09-10-2021, 07:11 AM
  #503
The Lotus seems to come with a small spoiler and on the medium wheelbase.
Now I need to think Do I want an M-06 on the side or can I wait until body comes out independently of chassis..
kwkride likes this.
Zanquis is offline
Old 09-13-2021, 01:31 PM
  #504
Dan
Dan's Avatar
Ok, missed TQ by 8 tenths and brought it down to the wire for an A3 battle in the triple A mains. Couldn't convert it to a win but it was a very close battle so I will stick with the M08.
Dan is offline
Old 09-13-2021, 06:53 PM
  #505
kwkride's Avatar
Good racing with you again Dan. Which tires were you running? I was still running the Ride tires and need to replace them. Thanks
kwkride is offline
Old 09-13-2021, 10:40 PM
  #506
Dan
Dan's Avatar
You too! I was running the new hard tires at the shop with the hard inserts. Glad we were allowed to use those instead of being stuck with the Ride tires.
Dan is offline
Old 09-14-2021, 04:48 AM
  #507
kwkride's Avatar
Thanks! When I got to the 'Plex Friday afternoon they were already out of Mini tires, so I was running the Ride tires that I had (which ripped the sidewalls during the Mains). Still a fun weekend!
kwkride is offline
Old 09-14-2021, 07:36 AM
  #508
Raman's Avatar
So you placed 2nd overall? 👍
Raman is offline
Old 09-14-2021, 07:37 AM
  #509
Raman's Avatar
What are these hard tyres? Tamiya? Or Ride?
Raman is offline
Old 09-14-2021, 08:04 AM
  #510
kwkride's Avatar
New tires that are legal for the TCS M-Chassis class
Tamiya 60D Radial Tires (soft) #54995
Tamiya 60D Radial Tires (hard) #54999
kwkride is offline
