Old 02-28-2006, 06:50 PM   #1
volracer's Avatar
Send a message via ICQ to volracer
Default Foam Tire Recommendations
I have a FT TC4. I want to buy some foam tires to run on a track set on an old tennis court, where we do not use any additive on the track. The track is a tight twisty course. Any suggestions?
volracer is offline   Reply With Quote
Old 02-28-2006, 07:15 PM   #2
Andrew Gray's Avatar
Go with Jaco tires, either purples front and rear, or purple front and double pink rear.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 02-28-2006, 07:25 PM   #3
Send a message via AIM to mush104
go with jacos like andrew said but i think my ft tc4 works with dbl pink orange in front and dbl pinks i rear.
mush104 is offline   Reply With Quote
Old 02-28-2006, 07:28 PM   #4
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
But you gotta remember what kind of surfice he is racing on, why don tyou guys use rubber tires?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 02-28-2006, 07:34 PM   #5
volracer's Avatar
I have several sets of rubber tires, but I wanted to try foam tires. Some other drivers last year were using them with 19 turn motors and modifieds. I just wanted to try foams, just did not know what to buy.
Old 02-28-2006, 07:47 PM   #6
my bad i thought you were racing indoors on carpet
Old 02-28-2006, 10:01 PM   #7
MAD916's Avatar
GQ's are working great up here and they have all the compound including two stages etc. we sell them for 12.99 a pair. plus the rims are amazingly strong...
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 02-28-2006, 10:21 PM   #8
Tim W.'s Avatar
i would go with parma. purple front purple rear.
Tim W. is offline   Reply With Quote
Old 03-01-2006, 10:14 PM   #9
Here in New Zealand we run foam tires all the time.
Use nitro TC foam tires not Jaco or Parma indoor tires.
Jaco nitro shoes, and GRP (fast tires, Ellegi,Power tyres) will work very good.
Try using 37s all round would be a good starting point i think. And then you can see if you want to go harder or softer, depending on how much grip there is. This might sound strange but also try 26mm tires front and rear i think you will find that it works a little better than wider tires on the rear.
Hope this helps.
Simon A is offline   Reply With Quote
Foam Tire Recommendations xman Nitro On-Road 10 07-07-2008 11:26 AM
NTC3 tire recommendations? infosponge Nitro On-Road 0 06-18-2006 06:52 PM
Tire Recommendations caleb77 Singapore R/C Racers 0 05-24-2005 09:31 PM
Foam recommendations wrxmy99 Australian Racing 10 06-16-2004 07:38 AM
Tire recommendations RoadRat Electric On-Road 2 06-07-2003 09:42 AM
