Spring rates and spring kits >
Old 03-01-2019, 07:22 AM
Trader Rating: 14 (100%+)
Default Spring rates and spring kits
So I race primary outdoor on smooth asphalt. It gets treated but I would still consider it fairly low traction. My first few outings i struggled with setup since I've never been good at figuring things out and after speaking to a few of the guys they found out I was using springs that were much too hard. Luckily I had amassed quite a few spares but even then my softest springs (12lbs) were too stiff. Were we compensating for some other setup changes that could be made? I based it recommended setups and tweaked it to my driving style from there.
Also I was browsing around last night and didnt find many kits of springs for sale or at least a wide enough spring rate that I used to see. Who is selling springs these days?
Double D Donuts is offline
Old 03-01-2019, 08:08 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
n low grip asphalt i had better results with a stiffer spring and softer shock oil, like 37.5 shock oil and like 17lbs spring. it also depends on your car set up and tires.
Marcos.J is offline
Old 03-01-2019, 08:13 AM
LzREngineering's Avatar
If you're on about touring cars, 12lbs should be plenty soft (12lbs = c=2.1). Most racers run at least 14.5lb (c=2.5).
What angle are your shocks at?
LzREngineering is offline
Old 03-01-2019, 04:13 PM
I dont remember the particulars of the shock angle. I can always grab the car if youre really curious.
Old 03-02-2019, 04:42 AM
DD
Go to this page find your car, and check out some of the set ups for asphalt.
It should give you an idea of what others racers have used
tekin112000 is offline
Old 03-03-2019, 06:19 AM
Thanks!!
