Black Carpet setup tips for carbon fiber chassis >
Old 02-23-2019, 11:12 AM
Default Black Carpet setup tips for carbon fiber chassis
I have a couple carbon fiber chassis's and haven't ran too much on black carpet. Im looking for some setup tips. Thanks
TeamThibault is offline
Old 02-23-2019, 11:54 AM
purplerain's Avatar
Tire glue is going to matter much more than chassis material for performance. Ask a local racer what diameter they glue to.
purplerain is offline
Old 02-23-2019, 01:26 PM
Zerodefect's Avatar
Glue the outside sidewalls. All of them.
Soft springs. And whatever damping you use, keep a close eye on it.
Zerodefect is offline
Old 02-23-2019, 08:24 PM
Carbon vs aluminum chassis on black CRC carpet ain't going to make a significant difference. I've ran both and lap times were negligible.
johnzhou2476 is offline
Old 02-23-2019, 08:25 PM
If you had a choice, go with the thicker 2.2 mm carbon chassis for black carpet.
Old 02-23-2019, 09:17 PM
Only glue the outside sidewalls of your front tires. Do not do the rears.
faqcya is offline
Old 02-23-2019, 09:48 PM
DBM
If you have any options for stiffening your chassis, run them.
DBM is offline
Old 02-24-2019, 09:33 PM
Honestly depending on the class and traction carbon vs alloy doesn't matter, I've seen crc tracks feel like asphalt and some that are sprayed and preped. Usually with carbon cars gluing the front tires works great .I highly advise looking at some setup sheets online for your car. Hard to tell you what you need to do when a car like a photon for example has three different chassis that all have different levels of flex.
Hopscotch is offline
