TC Mod esc setup advice for 7.5 >
Like Tree1Likes
  • 1 Post By Troy Carter
Old 02-22-2019, 11:03 AM
Default TC Mod esc setup advice for 7.5
I run USGT but like to venture into TC mod. I'm starting with 7.5 motor instead of conventional 4.5 to 5.0 turn. The track I run at is fairly large black CRC carpet. My esc is HW XR10 160a. I can't find any esc setup on petit RC for 7.5 only 4.5 & 5.0. Can someone give some baseline setup advice regarding boost and turbo, I assume it would be more than 4.5 & 5.0, but how much more. My motor (McClan) can timing is currently set @ 20.
johnzhou2476 is offline
Old 02-22-2019, 11:13 AM
My FDR will be around 6.5 to 7.0
Old 02-22-2019, 01:19 PM
Trader Rating: 22 (100%+)
Since you are looking for less motor than a 4.5t already I would just duplicate a typical 4.5t setup the the 7.5t. No need to push a 7.5t hard when you could just put a different motor in.
Honestly, start with the box setup for the ESC and have fun I think that setup is a fair starting point.
johnzhou2476 likes this.
Troy Carter is offline
Old 02-22-2019, 01:35 PM
Thanks I'll do that. For USGT, my rear toe was -1 and 0 toe in the front. For TC, I notice most are running a much more grippier setup, like -3 toe in rear and 1 to 2 toe out in the front, camber also seems to be higher with TC mod. Belt tension is also tighter with TC mod. Is there anything else I should be aware of when transitioning to mod? For example, should I go thicker in the rear diff fluid. I'm using 8k now for USGT. I was also told not to glue the sidewall in the rear, only front for mod.
Old 02-23-2019, 12:00 PM
purplerain's Avatar
It is very rare to glue the rear tires in most conditions.
Generally, 10k in the rear is a good starting point and helps smooth out the car.
purplerain is offline
Old 02-24-2019, 08:08 PM
thereís actually some good reasons to start with a 6.5 or 7.5 motor shoot me a pm if youíre still interested Iíll give you a good hobbywing starting point setup for those motors
Larrysraceprep is offline
