Old 02-27-2006, 09:22 AM   #1
Default Need a little help
I just purchased a used GT7 speed control for my sons 19 turn car, we previously bought new a GT7 thats in his stock rubber car. my question is
the new one we bought has 2 black, one blue, one red wire, the used one we bought only has 2 black and one red wire, how in the heck do I hook this unit up. Sorry if it`s a dumb question but we`re noobies here.
JERRYT is offline   Reply With Quote
Old 02-27-2006, 09:39 AM   #2
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
First off Jerry, the only dumb question is the one not asked. If you look on the case of the speedo, it'll say which wire is which. The red wire is the battery and motor + lead. One of the black wires is connected to (mot -) and the other is connected to (bat-). Just hook them up accordingly. Make sure to look on the case of the speedo to be sure which wire is which. Also, just to be safe, I'd change the motor - wire to a different color like blue or something along those lines. You don't want to mistake which is which and wonder why the car doesn't move and there's a plume of smoke coming out of the speedo...
Tony
RcCzarOfOld is offline   Reply With Quote
Old 02-27-2006, 09:44 AM   #3
BugFreak's Avatar
Check out novaks instruction manual: http://teamnovak.com/download/instru...fs/GT7_ins.pdf
Svein E. Pedersen
- tamiya4ever -
BugFreak is offline   Reply With Quote
Old 02-27-2006, 10:00 AM   #4
Default ESC
So let me get this straight, the red wire goes to both the mot + and bat +, do I have to split this wire correct? That what I gather, also I have the instructions on my other speed control, but they list the blue wire which I do not have.
Old 02-27-2006, 10:24 AM   #5
Just copy the wiring in your sons stock rubber car. If you need extra wire get it from your LHS. Or you may have some wire left after installing the GT7 you bought new.
andsetinn is offline   Reply With Quote
Old 02-27-2006, 10:25 AM   #6
BugFreak's Avatar
You are correct regarding splitting the wire, and I have done it this way:
You can also take one wire to one of the sides on the enbells + tabs, and solder another from the second tab to the battery.. hope this helps
Svein E. Pedersen
- tamiya4ever -
Old 02-27-2006, 12:12 PM   #7
Default ESC
Thanks thats what I though, didn`t want to havea barbeque
