Tamiya TB03 VDS Touring >
Like Tree2Likes
  • 1 Post By walrusjon
  • 1 Post By Tom1977
Old 02-04-2019, 08:47 PM
walrusjon's Avatar
Default Tamiya TB03 VDS Touring
I bought it on 2017 and just build recently. Its a very good handling shaft car I had ever built... Its a drift spec. touring origin and you can change it to normal touring by Tamiya option 84207 ackerman steering set. The first run is so impress of the well handling due to the chassis weight distribution, middle motor position. Its steering is so sensitive due to I set up the narrow suspension mount (XC,XC for front and XD,XA at rear) and alum. c hub with bearing from eagle racing. I will change the track width and lower gear ratio on next run to test its acceleration.
Tom1977 likes this.
walrusjon is offline
Old 02-04-2019, 09:23 PM
Tom1977's Avatar
I've one, too. Bought it in 2013 as one of the last kits in Europe. It's definitely one of the most beautiful chassis from Tamiya. Similar concept to the today's TB Evo 7.
Buildt mine as a drift spec. Ackerman steering set is still NIB.
walrusjon likes this.
Tom1977 is offline
Old 02-04-2019, 09:51 PM
walrusjon's Avatar
Yes. You are so lucky to get the last one. Its available on japan yahoo auction only now.
