VTA gearing on a 25.5 2018 xray t4...need help!!! >
Like Tree1Likes
  • 1 Post By Marcos.J
Old 01-30-2019, 02:17 PM
Default VTA gearing on a 25.5 2018 xray t4...need help!!!
Hey there
looking for some help with gearing in a 2018 xray t4 setup to run 25.5 VTA. The motor is a trinity revtech...any help would be appreciated
just8av8 is offline
Old 01-30-2019, 04:00 PM
Parnelli's Avatar
Trader Rating: 17 (100%+)
Thumbs up XRay chassis FDR
When I ran in VTA I was at 3.5 to 3.7 FDR with a 25.5 Novak Boss
Parnelli is offline
Old 01-30-2019, 04:24 PM
IndyRC_Racer's Avatar
Please post this question in the main VTA thread here on RCTECH. Here is the link...
U.S. Vintage Trans-Am Racing Part 2
Most of the newer motors will require a bit of different gearing when compared to the Novak 25.5 motors. Also the size of the track will affect the gearing a bit, so please include that info if you can. There should be someone in the VTA thread that should give you a good starting point for gearing and timing with the motor that you are using.
You can also post your question in the Trinity and Revtech Motors tjread here on RCTECH. Here is the link...
Trinity and ReVtech Motors discussion
Hope this info helps.
IndyRC_Racer is offline
Old 01-30-2019, 06:11 PM
Trader Rating: 45 (100%+)
Is the motor one of Revtech's new ones? I agree with 3.5 to 3.7 FDR. I am running an older Reedy 25.5T with a 3.3 FDR. One track I run is long and free flowing, the other is medium and a bit technical. I have been running temps from 105 to 111 degrees. I think most racers will agree that set-up of the car and gearing are an experiment until you find the combo you're happy with.
jammin684 is offline
Old 02-01-2019, 03:45 PM
RussF's Avatar
Trader Rating: 22 (100%+)
Originally Posted by just8av8 View Post
Hey there
I have a 2017 T4 with a D3.5 that I run 96/47-50.
RussF is offline
Old 02-01-2019, 06:17 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
the new revtech 25.5 likes rpms Iím running in vta in a medium size indoor track at 4.09 . I would start at 4.1 and look at the lap times , my motor is like 100 degrees
dave-man likes this.
Marcos.J is offline
