Old 02-26-2006, 10:55 AM   #1
Default Charging Amp??
Hi, I have a couple Questions about charging amp. My battery have a label in back that say charge at 2-3 amp rate, and my charger have a marked label amp for nimh recommend amp, which say 0.5-3 amp. That's what I did and work fine. After reading alot of post, I see alot of people charge at 5-6 amp, is it because they have matched cell that can do that?? will it hurt the battery if I turn the amp up?? I just purchase a couple new battery pack which don't have chargeing label on them and wonder what amp to charge at.
-Old battery
Orion super duty 3000 nimh stick pack
-New battery
trinty sanyo 3000nimh stick pack
-Charger
integy 16Xpro
duratrax intellipeak pulse
evilphu is offline   Reply With Quote
Old 02-26-2006, 12:51 PM   #2
Superkarter's Avatar
Charging at 5-6 amps gets the batteries done quicker but does decrease the runtime slightly and the battery gets punished a bit more charging at those amps so for u I would charge at a slightly lower amp 3-4 and have the battery last longer.
Superkarter is offline   Reply With Quote
Old 02-26-2006, 05:02 PM   #3
Good to know, I'll keep it at 3 amp for now. Any other input in the amp??
Old 02-26-2006, 06:43 PM   #4
alcyon's Avatar
yes,if you are rich then charge at high amps.your batteries will last for 6 months only.i charge at 3 - 4 amps,and my batteries can still be used up to 2 years.but of course by that time there is a noticablew drop in performance,but if u charge at 6 all the time,the the drop will come by 6 months.
alcyon is offline   Reply With Quote
Old 02-26-2006, 06:44 PM   #5
TAO3RS's Avatar
Send a message via Yahoo to TAO3RS
3amp is too low. imho
try 4.5-5flat.. just dont go beyond 6
TAO3RS is offline   Reply With Quote
Old 03-15-2013, 07:47 AM   #6
SlideMasteR's Avatar
yip benlinus must be a bot as this is car audio advice !!
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-15-2013, 08:39 AM   #7
Jethroz's Avatar
Trader Rating: 51 (100%+)
It appears that is the case. I think the reference to Orion is triggering the car audio responses. Orion has made some of the best and most popular car audio amplifiers.
Jethroz is offline   Reply With Quote
Old 03-15-2013, 08:56 AM   #8
Geezatec's Avatar
old schooled. Charger able to charge .5-3amps. Charger charges upto 3amp or 3000mah. .5-1amp for peaking the battery. Nimh batteries you can charge upto .10-.20% over the ah(amp hour) rating. Heat is the worst thing to do. Overcharging like doubling the ah rating will overheat or overcharge will damage the cells, may burst while charging, especially with old NiMh batterries or NiCd. If overcharging DO NOT leave them unattended. Have a temp gauge near. If you cant hold by hand its overcharged, Me personally wou8ld not sharge over .10% with these old type of batteries. LiPo's and LiFe a whole different chemistry.
Geezatec is offline   Reply With Quote
Old 03-15-2013, 12:00 PM   #9
SS LS1's Avatar
Trader Rating: 23 (100%+)
Seriously!?
Look above..... The original topic was posted over 7 years ago! Nobody cares about charging Nimh batteries anymore. Only reason this thread popped up was from a bot posting about car audio capacitors. Have a read above sir.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 03-15-2013, 12:15 PM   #10
Wow this thing is reviving all kinds of old useless threads. They did this one too.
http://www.rctech.net/forum/electric...869-radio.html
Maybe a mod should look into this.
ATXPro4 is offline   Reply With Quote
Old 03-15-2013, 12:50 PM   #11
Geezatec's Avatar
For a rookie on the thread, just glad to help him on the past. Experience on NiCd and NiMh still good to know. Lipo and LiFe chemistry a bit different. RCTech threat that's what it here for. RC stuff past or Present.
Old 03-15-2013, 03:07 PM   #12
I have been charging at 10 amps for 2 seasons, While i do not notice any decrease in performance, the internal resistance has gone up slightly.
I use a turbo 35 with the newest software & revtech 2s 65c batteries.
I now charge at 12amps, 4.27v per cell, and have zero issues with the batteries.
And i almost never balance them
Shortbusallstar is offline   Reply With Quote
Old 03-15-2013, 03:56 PM   #13
The high charge rate damaging batteries in only a few months pertains to NiMH batteries. Most of the newer LiPo batteries can be charged at 1 to 2 c with a balancing port with little degradation in performance. Until they begin to reach their max number of cycles. Usually in the 200's. Then their voltage will begin to fall off quicker from max and capacity will begin to fall off quickly.
Old 03-15-2013, 08:04 PM   #14
COBRARACING's Avatar
Max 1c and always balance charge .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
charging hillbillyrcer Micro and Mini Scales 9 01-16-2008 03:58 AM
Charging ? NitroMaxx3.3 Nitro On-Road 7 06-18-2007 02:57 PM
need help with charging please mikezilla Australian Racing 9 04-11-2006 05:17 AM
Charging. How to? Mossie Australian Racing 14 01-27-2004 02:32 PM
