Old 02-26-2006, 10:12 AM   #1
Default Soldering batteries - help
Hi,
I need some help soldering batteries... I have tried all the soldering irons I have at home (60W and 100W) and neither makes the tin stick to the battery... what type of soldering iron should I use?
Also, what about using JB Weld?
Also, what about cold heat soldering battery packs?
TIA
D_o_S is offline   Reply With Quote
Old 02-26-2006, 10:28 AM   #2
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
make sure you scuff up the terminals, i use 300 grit sand papper , it will give the solder something to ancor to
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 02-26-2006, 10:39 AM   #3
I did, I Dremeled both sides of each cell...
Old 02-26-2006, 10:52 AM   #4
Still Bill's Avatar
You want at least a 60W soldering iron with a 3/16" wide flat tip.
Let the tip completely heat up before using (tinning) so it can transfer heat more effectively to what you are soldering. Repeatedly clean the tip and re-tin for every connection you use it on.
As Jason says, you need to slightly scuff up both ends of the cells before soldering. I use a Dremel to do that. I also pre-solder the scuffed cell locations where the bars will be attached.
When done properly, your hot iron tip will only be making contact with the surface of the cell for 5-10 seconds to pre-solder and solder. If it is taking longer...Stop!...You don't want to overheat the cells. Let them cool back down and rethink what you are doing.
Use good rosin core solder...Deans, etc. Use a cell building jig to hold it all together while you solder.
Seems that Balak Racing had a good article on building packs...with pictures.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-26-2006, 10:59 AM   #5
use deans solder, rosin core solder. also what type of tip is on your soldering iron ?
pencil type types dont work as well. a screwdriver (chisel) tip works the best.
baih is offline   Reply With Quote
Old 02-26-2006, 11:25 AM   #6
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I use Radio Shack computer solder...works awesome! And I still use the Weller 40 watt cheapie iron, and that also produces excellent results.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 02-26-2006, 11:25 AM   #7
I'm using a chisel type tip...
Unfortunately, I cannot get deans solder... however, what should I ask for at the shop? Rosin core solder?
Old 02-26-2006, 12:45 PM   #8
are there any electronic stores near you.
get rosin core solder, or if the store has kester "44" solder. dia .031 is what i use.
Old 02-26-2006, 02:42 PM   #9
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
yes, deans is greeeeeeaaaaaaaat!!!! Its a 60/40 resin core. i dont' like radio shacks' solder, deans works muuuuuuuuuch better.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 02-26-2006, 03:03 PM   #10
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
here you go...
http://www.taobracing.net/review_batterysoldering.shtml
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 02-26-2006, 05:37 PM   #11
James35's Avatar
And if you want the best, check out this soldering gun.
James35 is offline   Reply With Quote
Old 02-26-2006, 05:57 PM   #12
lol, industrial, lol. I've always been parcial to a blow torche and sitck of pipe solder, hehe.
Old 02-26-2006, 07:08 PM   #13
Emaxximuss78's Avatar
You might try using some flux.
You can get it at radioshack. Scuff the batt. Then put some flux on it.
Then tin it. It helps out a great deal. I use a cheap 40 watt radioshack iron and have no prob soldering batts when I use the flux
Emaxximuss78 is offline   Reply With Quote
Old 02-26-2006, 08:02 PM   #14
yeah flux makes a big difference. And i always scratch a coss and then cross again ontop of the cell with a reamer tip or a craft knife blade.
Make sure that you apply the sodering iron on for long enough so that the solder can melt and bond onto the cell. But dont hold it for to long
Simon A is offline   Reply With Quote
Old 02-27-2006, 04:15 AM   #15
if you don't wanna deal with flux, deans already has it in it. Also, it may be wise to score the batter bar ends as well as the cell.
Best Soldering Iron for Batteries? RCpurplecow Electric On-Road 37 05-02-2008 03:13 PM
soldering batteries SRBMOJO Electric On-Road 9 07-06-2007 03:11 PM
Soldering Batteries tc4 Australian Racing 10 09-23-2006 11:41 PM
Soldering batteries - gap or no gap? D_o_S Electric On-Road 11 02-26-2006 10:11 AM
Soldering Batteries AssociatedRacer Electric On-Road 3 03-15-2003 07:53 PM
