Old 02-27-2006, 07:42 AM   #16
DOS
Just curious but what brand/type of batteries are you building?
Lano is offline   Reply With Quote
Old 02-27-2006, 10:36 AM   #17
Originally Posted by Lano
DOS
I'm trying to solder some 1900 I had left over...
I went to the shop today, I got some new tin (not deans, but 60/40), and some special fluid to put on before I solder...
The problem is though, that the solder will not stick to the battery, when I try to tin it, it just makes a sort of bubble... any ideas?
D_o_S is offline   Reply With Quote
Old 02-27-2006, 10:40 AM   #18
James35's Avatar
Soldering batteries is one of the hardest things to solder since the mass of the battery sucks the heat away from your soldering gun/iron. An iron or gun with a big tip helps a lot.
James35 is offline   Reply With Quote
Old 02-27-2006, 10:48 AM   #19
The reason I asked what battery is because I'm having exactly the same problem with some IP3600. I'm using flux, 60/40 solder, hot iron/large tip and roughing up the battery but I just can't get the solder for flow on the battery and yes it seems that the battery is working like a large heat sink. I am only experiencing this problem on the IP3600 and neve had the problem with GP. I gave up tining the battery and have just tined the battery bar only. This seems to work.
Old 02-27-2006, 01:15 PM   #20
Well, I managed to do it somehow... the only thing I know is I don't want to do it again...
Thanks for all the help
Old 02-27-2006, 07:38 PM   #21
Still Bill's Avatar
Assuming that you go to a track, check out someone building packs and what they do. Should be easy from that point onward.
Or...There are always pre-assembled packs.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-27-2006, 07:41 PM   #22
Still Bill's Avatar
Sounds like a dirty surface...Clean the cells with motor spray, wipe and dry before attempting to solder.
Otherwise, a bubble of solder is not necessarily bad if it is well stuck to the cell.
Best Soldering Iron for Batteries? RCpurplecow Electric On-Road 37 05-02-2008 03:13 PM
soldering batteries SRBMOJO Electric On-Road 9 07-06-2007 03:11 PM
Soldering Batteries tc4 Australian Racing 10 09-23-2006 11:41 PM
Soldering batteries - gap or no gap? D_o_S Electric On-Road 11 02-26-2006 10:11 AM
Soldering Batteries AssociatedRacer Electric On-Road 3 03-15-2003 07:53 PM
