Old 02-12-2003, 01:54 PM   #106
OSherman's Avatar
Default Display
I know of 4 people (including myself) who run the 3PK..only one of us have had 'display shutdown'..[radio still works (transmits signal) you just cant see any adjustments you wish to make...]
3 of us all bought ours from the LHS...the fourth, which experienced 'display shutdown' , i don't know yet where it originated..will ask him to see, i do know he does have ties 'overseas' though...interesting...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-12-2003, 02:01 PM   #107
OSherman's Avatar
display contd.
furthermore, I do notice on my display whenever in warm surroundings (outdoors during a race day, or rite after unpacking my equipment from the trunk of car) there is a little 'rainbow haze' in one protion of the screen ..best seen when display is turned off....it doesn't affect the display output, everything displays correctly....and the 'haze' is not permanent..one day its ther, the next day its not...i called myself monitoring it over the course of a month, and it comes-and goes..noticing it only during the warmer part of the days that it does occur...I'm not worried though....
all-in-all, I love this radio...
•KO Propo America
•EXOTEK
Old 02-12-2003, 02:04 PM   #108
rc-zombies's Avatar
Default Re: display contd.
the LCD screen might be temperature sensitive...haven't seen that happen to mine yet...still cold up here. I'll keep an eye on it when the weather gets warmer.
Overall the radio is awesome!
Old 02-12-2003, 06:42 PM   #109
GregH's Avatar
Send a message via AIM to GregH
I have a question about receiver's. I'm currently using the HRS in my 8th scale with no problems, digital JR servo's. My problem arised when I tried using a older PCM receiver. The #'s on it are FP-R113iP on the case. I've gone through the radio and know how to change all the settings in mod-mode. I'm using my current crystal that came with the HRS receiver. Is the receiver I mentioned above compatible with the 3PK?
GregH is offline   Reply With Quote
Old 02-12-2003, 07:02 PM   #110
Trader Rating: 2 (75%+)
Thumbs up FP-R113iP
Yes, you can run that recever on the 3pk.....Mine came with it.
I also have another R113iP recever that is older and it works!
I race on-road nitro and the receiver is mounted next to the fuel tank. I have had problems with the receiver/radio go into the fail-safe mode or no signal transmitted. I believe that fuel got to the receiver and cause this. So now I have it in a shrink-rap now. BEWARE of any thing getting on the receiver...it is much sensitive then other receivers!
PUNISHER is offline   Reply With Quote
Old 02-12-2003, 07:10 PM   #111
GregH's Avatar
Hummm, the receiver was gotten from a friend that ran oval years ago. I mean like the better part of 15 years. If it was a wide band receiver, wouldn't that affect it?? I can't get it to work with a TC2 that worked before I put the PCM reciever in.
Old 02-13-2003, 02:12 AM   #112
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally posted by BOLISARIO
I'm thinking about getting a 75mhz PCM 3PK. I currently have an R1(for a few years now) and I'm getting tired of the 1.5-2 hrs of battery time i'm getting from it. I was wondering, if I make the switch, will I have to change the servos and other electronics(I have a Hitec steering servo with JR connectors, JR throttle servo, and 1100mah Rx pack) to accomodate the Futaba Rx?
What runtimes are you getting from 1800-2000mah(8cells)?
How's the whole quality and durability of the radio? No persistent LCD problems?
Is $265 a good price for a 3PK with PCM receiver?
Can anyone help me? Thanks
BOLISARIO is offline   Reply With Quote
Old 02-13-2003, 03:05 AM   #113
PHANTOM's Avatar
One thing for sure about the battery runtime, it's super lasting.... I can go for 2 full race days without charging, 3 x 7mins heats and 45mins main per day. On top of that, there's about an hour of practice rounds.
PHANTOM is offline   Reply With Quote
Old 02-13-2003, 08:22 AM   #114
Thumbs up
The R-1 is a battery eating radio.....
I have too gone a whole race day with my 3pk with out charging it!! I'm using 1800mah on my 3pk and it seem to be just fine.
I keep my 3pk in a case when not in use on the pit-table and have no problems with the LCD screen.
$265 is a good price for the 3pk.....thats about how much i got mine for!
Old 02-13-2003, 08:31 AM   #115
RC Nitro's Avatar
Second on the price. I have run the stock 700 mah pack for both classes with put a hitch. (3) 5 min qualifier and a main plus the (3) 8 min quilifier and main for 1/12. 2.5+ hrs on the display. I also have a 1500 mah pack I use to use in my 3PJS. Overall I love the radio. No display problems for me either.
RC Nitro is offline   Reply With Quote
Old 02-13-2003, 11:25 AM   #116
BOLISARIO's Avatar
Thanks for the feedback. Can I still use my hitec(JR connectors) and JR servos and Rx pack? Or does that have to change?
Old 02-13-2003, 11:28 AM   #117
Thumbs up
YEAH SURE!
I'm using a JR servo on mine!!
Old 02-13-2003, 11:52 AM   #118
RC Nitro's Avatar
PCM & FM (PPM) yes. HRS, you need a digital servo and 6.0 volts. That is noted in the manual. FYI manual is online on the futaba site.
Old 02-13-2003, 12:33 PM   #119
Exclamation HRS
Thats correct...HRS needs a digital servo.
Old 02-13-2003, 12:40 PM   #120
che
che's Avatar
Where are you guys finding them locally for $265?
(US Magnum branded, not Megatech labelled) ...
che is offline   Reply With Quote
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy Australia For Sale/Trade 4 11-22-2015 02:56 PM
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy R/C Items: For Sale/Trade 0 08-28-2006 12:18 AM
Futaba HRS 75mhz recevier - Futaba Digital servo s9451 - Novak cyclone esc 4SALE alltech R/C Items: For Sale/Trade 11 10-14-2005 07:15 AM
Futaba 3PDF FM Pistol Radio, Futaba FP-R133F FM 3 Channel Receiver, FM 66 xtal 403forbidden R/C Items: For Sale/Trade 16 05-19-2004 09:34 PM
Futaba 3PK $260, Futaba R203HF $80, R113IP $75, Futaba $9450 $80, OS 12TR $135 smash123 R/C Items: For Sale/Trade 2 02-13-2003 04:03 PM
