Old 12-09-2002, 09:40 PM   #46
hurhur's Avatar
Just a couple of questions on the 3pk here..
1) HRS has no PCM features (eg: stops car when glitching happens)?
2) Are Sanwa ZR, VR, VB etc etc servos compatible with the HRS unit?
hurhur is offline   Reply With Quote
Old 12-09-2002, 09:47 PM   #47
Wolf's Avatar
Send a message via ICQ to Wolf
Default Will old 3pj module work?
Hi, It is known that Hi-Tech TX module work with the 3pk. How about old 3pj TX module? (PCM & PPM) The manual said it will not work. How about real life experience?
According to the manual, HRS also have fail safe function. Don't know how it work in real life. Cause in the old days of 3pj, the fail safe doesn't work very much if there is another 3pj is running the same frequency in PCM mode. However, the battery fail safe did work.
Wolf is offline   Reply With Quote
Old 12-09-2002, 09:50 PM   #48
popsracer's Avatar
Default 3PK Failsafe feature
Hurhur;
According to the 3PK manual, Failsafe mode is ONLY availible in HRS and PCM modes. You need a plug-in Failsafe for standard PPM/FM receivers.
DIGITAL Servos ONLY with the HRS Receiver. So far most brands of Digital servos seem to work OK with the 3PK. You can use ANY type of servo with the other Receivers.
popsracer is offline   Reply With Quote
Old 12-10-2002, 01:08 AM   #49
Send a message via AIM to Dave Kurschner
Wolf, the Hi-Tec adjustable module works in the 3PK. Its in action at our track already.
Dave Kurschner is offline   Reply With Quote
Old 12-10-2002, 01:27 AM   #50
Wolf's Avatar
Hi Dave, Thanks. Is the module designed for use with both 3PK and 3PJ?
Old 12-10-2002, 01:28 AM   #51
TRF414M's Avatar
For PPM and PCM, you can use whatever you want. But we never try it with HRS though. This is only half the answer.
TRF414M is offline   Reply With Quote
Old 12-10-2002, 01:55 AM   #52
Wolf's Avatar
I'll choose to use PCM/PPM instead of HRS, due to the fact that PCM/PPM is more flexible on the receiver, servo and battery used. It's hard to tell the respond speed difference on the track. So there is no problem.
BTW, 3PK manual system is a great improvement from the 3PJ, very easy to understand and use. For the 3PJ, I can never figure out where are those functions are located and how to adjust without the manual.
Old 12-10-2002, 03:08 AM   #53
Trader Rating: 68 (100%+)
Originally posted by Bong
3pk question
pardon me if i sound like a newbie, but i haven't heard of anyone where i race using 9 cells on their tx. what exactly will a 9 cell do better than an 8 cell pack? if it'll perform better, then why didn't futaba come out with 9 cells instead of an 8 cell pack on their 3pk.
hi there, bong i was using a 9-cell battery pack in my old 3PJ. the advantage is higher voltage, which should increase range a bit. my car used to glitch on some parts of the makati track when i ran there before; switching to 9-cell seemed to eliminate the glitch. but im not suggesting that glitches are cured by 9-cell packs
btw, where did you get your 3PK with the transmitter pack? i couldnt find one so i got the set without the nicads. i bought 1850mah nimh AA's, which should last a while between charges, considering that the 3pk seems to be a bit easier on the batteries, even with the backlight.
marvi is offline   Reply With Quote
Old 12-10-2002, 03:44 AM   #54
marvi, try pitshop...i saw 2 sets last week!
maski is offline   Reply With Quote
Old 12-10-2002, 04:08 AM   #55
thanks maski
Old 12-10-2002, 04:55 AM   #56
Pyramid's Avatar
Just remove the screw covers and take out the other end. Just remember for the rear cover, there is one screw inside holding the other end.
If you want to pain them, I think it is better to ask some professional paint workshop to do it as you won't be able to just paint them with tamiya TS spray paint even if you applied primer first. I already did and failled, but they are easily removed with gasoline and it came gold again. By the way, it is metalizing proses for the gold color.
I will send mine to a paint shop on 16/dec and see what they can do for me as I required no sanding on its "EDM" finish.
Hope it helps
Originally posted by marvi
a couple of 3PK questions:
one more thing, i noticed that the gold colored plastic parts seem to be attached by screws (except for the module cover which slides off). are they easily removeable? are there different trim colors available, just like in the 3PJ with the different colored steering wheel and grip covers?
thanks for any info
Pyramid is offline   Reply With Quote
Old 12-10-2002, 05:50 PM   #57
ilaybrk's Avatar
my friend has a 3pk I took a modual #fp-tl-fm75mhz to his house it worked with his radio and he has hrs reciver it worked fine the modual came out of a 12 year old 1024 magnum pcm no problems
ilaybrk is offline   Reply With Quote
Old 12-10-2002, 06:01 PM   #58
Manticore's Avatar
R/C Tech Charter Subscriber
you need to do range test too !
Manticore is offline   Reply With Quote
Old 12-10-2002, 06:02 PM   #59
rc-zombies's Avatar
and response test...
Old 12-10-2002, 06:28 PM   #60
popsracer's Avatar
Default 3PK Perks
OK Guys;
Everyone was scaring me away from the HRS receiver, but now it looks like it works quite well with other brands of Digital servos.
So what problems, if any, has anyone had with their 3PK so far?
Thanks,
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy Australia For Sale/Trade 4 11-22-2015 02:56 PM
FS: Futaba R203HF HRS Micro Receiver + Futaba Transmiter FP-PK-FM RF Module 75MHz WogBoy R/C Items: For Sale/Trade 0 08-28-2006 12:18 AM
Futaba HRS 75mhz recevier - Futaba Digital servo s9451 - Novak cyclone esc 4SALE alltech R/C Items: For Sale/Trade 11 10-14-2005 07:15 AM
Futaba 3PDF FM Pistol Radio, Futaba FP-R133F FM 3 Channel Receiver, FM 66 xtal 403forbidden R/C Items: For Sale/Trade 16 05-19-2004 09:34 PM
Futaba 3PK $260, Futaba R203HF $80, R113IP $75, Futaba $9450 $80, OS 12TR $135 smash123 R/C Items: For Sale/Trade 2 02-13-2003 04:03 PM
