Old 02-25-2006, 09:12 PM   #1
Default 48 pitch vs. 64 pitch
I am getting ready to buy all new pinions and spurs and start fresh but I was wandering what is the difference between the 48 and 64? I know that the teeth count is different but which is better. I am running 1/12 scale on-road or carpet. What works the best all around? Thanks guys. Brent
weedeaterman7 is offline   Reply With Quote
Old 02-25-2006, 09:17 PM   #2
tbeardmore's Avatar
Go with 64 pitch -they allow finer gearing ratios. And I think they're more efficient for run time.
tbeardmore is offline   Reply With Quote
Old 02-25-2006, 09:25 PM   #3
Yeah i prefer 64p aswell. They are much harder to mesh but there
are better for 1/12 and all cars really.
Simon A is offline   Reply With Quote
Old 02-25-2006, 09:36 PM   #4
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Try Here for Titanium 64 pitch pinions.................
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-25-2006, 11:18 PM   #5
Super Moderator
Grizzbob's Avatar
True, while I think anyone'd be hard pressed to tell the difference in efficiency between 48 & 64 pitch gears, the difference in available gear ratios definitely favors 64 pitch, & that's what you need for 1/12 scale more than anything. You MUST have precise & fine control over the final drive ratio so you can get the right rollout for a given motor, your tires' diameter, the track layout, etc., & 64 pitch makes that a lot easier, even though they aren't quite as durable as 48 pitch & they're more difficult to get a proper mesh with. In the end, they're definitely worth it(& I even use 'em in my 1/10 scale touring car with no problems).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-26-2006, 04:50 AM   #6
Charles Godwin's Avatar
Go with 64dp , might take a minute more to mesh properly but it is worth it and they are alot more quieter, noise is a loss of energy (my science teacher told us that ) and more options on gearing
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-26-2006, 05:11 AM   #7
Hiya mate,
I would go for the 64 dp pinion/spur combo. They do run quieter and more efficiently. Go for TiR pinions. You really can't get any better pinions.
Paul
pwracing is offline   Reply With Quote
Old 02-26-2006, 05:54 AM   #8
AngryAsian's Avatar
64 pitch is more efficient thatn 48pitch. Practically speaking , it's the fine adjustment of gear ratio that is the biggest factor for most ppl.
If you run on a prepared surface then without a doubt, go for 64pitch. Some outdoors surfaces with lots of track debris are killer on 64pitch gears. In that case, go with the more durable 48. Or, if you are a heavy crasher, then depending on the car you're running 48 pitch will last longer.(talking about drivetrain shock..)
Otherwise it's 64 all the way..
AngryAsian is offline   Reply With Quote
Old 02-26-2006, 06:15 AM   #9
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
64dp
MR JOLLY is offline   Reply With Quote
Old 02-26-2006, 07:08 AM   #10
Thanks guys and a final question, what is the better traction compound and what are the diffreences. I am use to using the paragon products and the fxII in peticular. What are the others alll about. Thanks Brent
Old 02-26-2006, 07:14 AM   #11
MR JOLLY's Avatar
rubber on asphalt
foam on asphalt
rubber on carpet
foam on carpet
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
48 Pitch, 64 Pitch Alfalfameister Rookie Zone 11 01-29-2008 05:07 AM
Converting TC5 from 48 Pitch to 64 Pitch??? jdob Rookie Zone 3 06-23-2007 11:10 AM
64 or 48 pitch minnesh Electric On-Road 23 05-07-2007 10:34 AM
48 pitch pinions cheap/or trade for 64 pitch pinions Got Xray? Australia For Sale/Trade 2 05-26-2006 11:04 PM
Pitch LancerEVO Electric On-Road 3 03-25-2004 04:30 AM
