Xray chassis plate question >
Old 01-15-2019, 12:50 PM
dun4sho's Avatar
Default Xray chassis plate question
would a 2018 alum. Flex chassis plate fit a 2015 xray t4? Thanks
dun4sho is offline
Old 01-15-2019, 05:46 PM
Trader Rating: 22 (100%+)
No, 15 and 16 are basically the same 17+ moved to inline motor and servo mounts
Troy Carter is offline
Old 01-15-2019, 06:16 PM
dun4sho's Avatar
Ok thanks im looking for a 15 flex chassis none to be found....
dun4sho is offline
Old 01-15-2019, 09:23 PM
It might be possible to make it work. When I got my '19, before I built it, I held the chassis plate up to the bottom of my '16. The hole spacing for the servo mount looked the same, but the servo mount was moved inboard. And of course, the '16 servo mount doesn't have pins. The motor mount foot plate looked like it would fit the '19 hole pattern, but the hole for the button head screw didn't line up. There could also be an issue with fitting the combined motor mount + left layshaft bulkhead, since the motor mount was moved inboard.
Maybe I'll get a chance to test it this weekend with my friend's '19 flex chassis (he's currently using the full hard chassis).
grippgoat is offline
Old 01-16-2019, 04:10 AM
Yes you can use an 18 chassis. Besides the chassis, you will need an 18 motor mount plate. It is the piece that the motor mount attaches to. I just switched a 16 to an 18.
mooby64 is offline
Old 01-16-2019, 04:32 AM
Super Moderator
Slo_E4's Avatar
Trader Rating: 61 (100%+)
Yes it will work, Everything will bolt right up. You do not need a motor mount.
Slo_E4 is offline
Old 01-16-2019, 04:55 AM
dun4sho's Avatar
What about servo mount?
dun4sho is offline
Old 01-16-2019, 07:24 AM
You will have no problem using The 15 servo mount. The screw holes line up, but the chassis has locating holes for the 18 servo mount.
mooby64 is offline
