TRF TA07MS
#62
sakaguchinetshop C. Donath Aluchassis für Tamiya TA-07MS
this?
this?
#65
#67
#71
Good!
Can I ask what are the other models-brands you drive to compare with ta07ms? I would like tou buy one.. don't know if it is competitive... I am using a 419XR, right now.
#73
#74
I got sick of trying to shim aftermarket spurs on the center pulley. So I purchased the TA07 center pulley (18T). Part number OP-1722. New (IGR) is 2.05. It comes with one 840 bearing. You’ll need a second one. I had to shim the outside bearing .6mm to push the bearing out. Then add a small shim so it won’t bind when installing the black piece that keeps the belt from slipping.
