TRF TA07MS
#241
Anyone use this car in VTA if so has anyone had issues with the inside of the rim wearing the bottom edge of the arm upon suspension compression because these
wheels are so wide notice the little v notch in the arm and this is on all four suspension arms I have tried spacing out the wheels to no avail any suggestions would be great only option so far is to put limiters on the shock shaft to prevent the wheel from hitting there I have also ever so slightly shaved the arm but now it's a weak point
#242
#243
So has anyone had some proper testing time on the ms yet? Any thoughts or setups?
#244
I have a TA-07 Pro, but I'm tempted to buy the MS kit for carpet racing. As of this post (June 24, 2020), the price of the kit on Tamiya USA's website is showing on sale for $425.00 USD.
https://www.tamiyausa.com/shop/110-4...s-chassis-kit/
#245
#247
Agree, I have only ran it on black carpet and was too much flex with all the upper stiffeners attached.
The Christian Donath aluminum chassis made it much better, but too bad it bent easily (in my hands), bought 2 and bent them all already.
#251
So little bit of a surprise to me given the rarity of this car, at least in my experience, but looks like we're getting an MSX
https://www.thercracer.com/2020/09/4...announced.html
Hopefully like the 419X to the 419XR we'll get a conversion kit or at least have some cross compatible upgrades for the current MS
#252
I think it will get trf420 parts... if the change bulkhead + top deck and/or motormount I have to buy him
RIP money
#254
42364 TA07 MSX Chassis Kit
The TA07 has been a revelation since its first release, providing smooth and versatile drive in a single beltdriven setup. Now it gets an ultra-racy release in the form of the top-spec TA07 MSX chassis, based upon the TA07 MS (Item 42326).
• Features a choice of two new motor positions, which are slightly further rearward than Position 2 and 3 from the original TA07 PRO respectively. Motor and spur gear positions are reversed, improving traction under acceleration and when cornering.
• Dedicated chassis parts are used – 2mm thickness dual bridge type vertical frame, and a choice of carbon fiber or aluminum lower decks. Different combinations of upper deck part (4 total are included) are used for the different motor positions.
• TRF Super Short Big Bore Dampers are standard, but stays are also included for use with longer dampers.
• Features the revolutionary TRF420 suspension setup, with plenty of potential for fine-tuning your car including pinpoint alterations thanks to suspension mount bushings..
• Utilizes dedicated lower bulkhead, motor mount, and servo mount components.
• Features a longer 771mm drive belt.
• Comes in a stylish and handy carry case.
https://kentech.wordpress.com/2020/0...first-details/
#255
Running on carpet, an aluminum chassis was what I was hoping to have for my TA07MS...
I'm already sold! Expecting a Christmas release similar to the MS.
