Old 02-24-2006, 10:19 PM   #1
Suspended
Default wondering about batteries.
i have 6 cell packs with the batteries in a formation such as this:
and i always see them in a formation such as this:
what is the difference? and if i were to switch mine... i have the stuff to do it with ...do i need to discharge my batts ALL the way or can i not even do it because i dont think solder sticks if theres voltage running
the #1 noob is offline   Reply With Quote
Old 02-24-2006, 10:28 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Most high end cars only accept side by side ( |||||| ) packs as they sit lower in the chassis. Also most stick packs (===) are not comprised of matched cells. Whether to change or not really depends on what car they are for, if you're racing or bashing, and what you expect to gain. If you decide to do it, discharge the pack down to 5.4 volts and use a HOT iron so as not to damage the cells by exposing them to extreme heat (which happens when you leave the iron on the cell end too long when using a sub par iron). When rebuilding be sure to use a deans jig or the like to ensure the cells are properly alligned and to make it easy on yourself. If the packs you have fit I would leave them the way they are and just set aside some $$ to upgrade to a few decent used matched side by side packs rather than fuss with all that rebuilding. thats me and my 2 though.
Andrew
Old 02-24-2006, 10:40 PM   #3
Suspended
so basically cuz im not racing just forget it? im bored theres no more mods i can do with my car my soldering is downstairs screaming to be plugged in, i can hear him.
Old 02-24-2006, 10:50 PM   #4
If you're looking for something to do go throuigh your car and clean all the bearings. : )
Old 02-24-2006, 10:58 PM   #5
Suspended
with... i got so much cleaning stuff its unbleievable. like paint remover, denatured alcohol, wd40, silicon spray stuff i think it is... idk i got tons of stuff. and then i have two types of oil, thicker or runnier? and how exactly would i clean them?
Old 02-24-2006, 11:24 PM   #6
I would explain it but its been explained so much before so much better than I could. You ought to do a search for bearing cleaning. The search tool works wonders!!
Old 02-24-2006, 11:26 PM   #7
Suspended
i forgot about him, i thought he died... thanks
Old 02-24-2006, 11:30 PM   #8
Talking
i like the packs that go like this
( O ) ( o )
noobie is offline   Reply With Quote
Old 02-24-2006, 11:48 PM   #9
tbeardmore's Avatar
Talking
( O ) ( o )
I think the left nip is larger than the right - ??? and the right "mam" is larger than the left ???
tbeardmore is offline   Reply With Quote
Old 02-24-2006, 11:54 PM   #10
Suspended
titties, titties. ass and titties.
Old 02-25-2006, 12:52 AM   #11
huh?
Old 02-25-2006, 11:45 AM   #12
Suspended
mr search button... i thought he died
JUST WONDERING !!!!!! mini g Georgia Racing 30 05-09-2008 05:07 PM
just wondering chuchurocket Nitro Off-Road 6 10-01-2007 09:37 PM
Just wondering...... jeffb Electric Off-Road 0 02-24-2006 11:29 AM
wondering?? pro3racer R/C Items: For Sale/Trade 5 04-17-2004 05:31 PM
Just wondering.. GUNPOWDER Australian Racing 2 02-23-2004 01:14 AM
