Old 02-24-2006, 05:35 PM   #1
IB 4200's - assemble with which battery bars
Hi all,
I recently received the Trinity 6C Team VIS-PRO 4200 Matched Unassembled batteries, but am needing to know which battery bars to assemble them with. I went to my local hobby shop and they only had bars rated up to 3000. Please help! Thanks!
Shodin is offline   Reply With Quote
Old 02-24-2006, 05:37 PM   #2
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Doesn't matter, battery bars are generic. I've used the same ones (Orion Bones are my favorite) on everything from GP3300 to IB4200.
Anthony.L is offline   Reply With Quote
Old 02-24-2006, 05:43 PM   #3
Hmm, okay. The next question I have then is why are they rated for different mAh? One set was rated for 1200 & 1500 and another set was rated for 3000's. Same manufacturer.
Old 02-24-2006, 05:50 PM   #4
Battery bars rated for 1200 is for smaller cells(for 1/18 mini, etc), battery with 3000, 3800, 4200mah whatever, as long they are sub-C size, the normal battery bars from Trinity, Orion, Deans, etc all work great.
caveman is offline   Reply With Quote
Old 02-24-2006, 06:22 PM   #5
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
The normal sized battery bars aren't "rated" for any capacity cell. They just have slightly different shapes and offsets to allow them to fit that type of cell's geometry a little better.
-James
JamesArluck is offline   Reply With Quote
Old 02-24-2006, 06:33 PM   #6
CristianTabush's Avatar
To clarify, James is right, but in more laymen's terms:
Generally the newer edition bars work. Batteries used to have that hump on the positive end (as alkaline AA's have) and therefore the older bars were offset on the positive side. The newer bars are not offset becase the hump does not portrude on the newer cells. I suggest the deans pro bar version 2 or 3.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-24-2006, 07:10 PM   #7
Okay, onto the next question then. What about composition? Copper, silver, platinum? What should I really be looking for in a bar? Least resistance? More thruput on voltage or whatever?
Old 02-24-2006, 08:24 PM   #8
Super Moderator
Grizzbob's Avatar
Resistance & corrosion protection are really the only things to worry about, so either all copper or silver plated will be best, both have the lowest resistance, & while they can corrode, it still takes awhile & usually your cells are dead long before it gets bad. If you're really worried about corrision though, you can go with gold-plated bars, their resistance is not far off from copper or silver, & they have EXCELLENT corrosion protection(that's why the military & commercial aircraft industries use gold contacts in all their electrical connections).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-24-2006, 08:58 PM   #9
Thx Grizz. I was actually looking into gold-plated, but didn't know if the core material mattered all that much or not. Unfortunately, I haven't seen any of those in the local hobby shops here in the Tulsa area.
I guess the Dean's Pro v2 or 3 will be fine. Thanks for the help guys.
Old 02-24-2006, 09:08 PM   #10
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Copper or gold will be your best.
dgullickson is offline   Reply With Quote
Old 02-24-2006, 10:53 PM   #11
TadehI's Avatar
I use platinum orion battery bones very thin and efficient in heat transfer.
TadehI is offline   Reply With Quote
Old 02-25-2006, 12:29 AM   #12
Super Moderator
Grizzbob's Avatar
Oh, I didn't realize you're in Tulsa(do I know you? Have you been to Adams Creek Raceway?). If you haven't been there, stop on by Sat. evening & look me up(I'm easy to spot, always wearing OSU stuff & I have a dyno & laptop at my pit spot, & my cars are white, orange & black, ), & I can answer quations a lot more easily & show you some of the stuff that's available.....
Bob Seay
Go Pokes!!!
Old 02-25-2006, 03:12 AM   #13
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
I tried using Excel silver bars. From the package they dont look shinny but looked dull silver. But someone told me, the more dull silver it is, the more silver content it has. A little pricy though but it looked like a good buy.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-25-2006, 07:20 AM   #14
adams creek rocks!! and the r c pit stop is the bomb!! lol
see you guys there to nite
ps use the cooper ones they will be fine.
Pat McCracken
Pat McCracken is offline   Reply With Quote
Old 02-25-2006, 11:04 AM   #15
asw7576's Avatar
I don't have preference with battery bars..... most of the time I use Deans and MuchMore. My choice is thick bars and they must contain silver like Deans.
Battery Assembly - Battery Bars.. Choice...?? Bwadd2002 Electric On-Road 21 12-04-2006 09:36 AM
Battery bars kuzo Electric On-Road 4 11-04-2005 11:21 PM
Which battery bars Yokomo Aust Electric On-Road 1 05-08-2004 07:58 AM
Battery Bars ZER01 Electric On-Road 14 12-29-2003 12:39 AM
Battery Bars? derekjr_1 Electric On-Road 2 01-02-2003 04:55 AM
