Xray t4 setup sheet question. >
Closed Thread
Old 12-07-2018, 07:19 AM
Default Xray t4 setup sheet question.
Hi,
I have never used a setup sheet before and I am confused on the wheelbase shims. On the t4 '16 the manual shows putting a 1mm shim before and after the arm. How to you mark this on the set up sheet. To me it appears to only have provisions to mark what you put on the front of the arm. So am I right that in stock setup you would mark the middle 1mm because only one shim is in the front? A short wheelbase (front setup) would have both 1mm marked and a long wheelbase would have the 0 marked?
Sorry if my question is confusing. The only rc car I have ever raced before this car was a m18pro which doesn't have all these setup options.
Also does anyone happen to have an out of the box per the manual setup sheet for the t4 '16 filled out?
mrreet2001 is offline
Old 12-07-2018, 07:55 AM
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 208 (100%+)
Originally Posted by mrreet2001 View Post
Hi,
try asking here
XRAY T4'19 SPEC
Marcos.J is offline
