Sidewinder vs inline >
Like Tree2Likes
  • 1 Post By Nerobro
  • 1 Post By lighttravler
Old 11-26-2018, 10:14 PM
Default Sidewinder vs inline
can anyone give me he pros and cons on these 2 electric chassis kits?
lighttravler is offline
Old 11-26-2018, 11:16 PM
You've not given us nearly enough to go on. I suspect.. you're using drifter slang. If I were to guess... you're talking about shaft drive, versus belt drive chassis. But you gotta tell us.
Nerobro is offline
Old 11-27-2018, 12:27 AM
Go to dragraceconcepts site and look up his chassis electric kit. Pro stock and pro mod is what I am referring to
Old 11-27-2018, 06:54 AM
Wow, you really buried the lead there.
IIRC, pan car (sidewinder) style, has motor inertia help hold the front of the car down. I suspect, the inline motor setups are there for scale appearance. I think.... you should check the rules of your local drag racing group. Something tells me that there will be rules on what is legal for whatever class you want to run.
30Tooth likes this.
Nerobro is offline
Old 12-01-2018, 03:56 PM
Airwave's Avatar
I can't understand why somebody would chose inline. The transmission is less efficient that sidewinder...
By the way, you should consider adding an additional pinion between the motor pinion and the spur gear. It will make the motor run in the same direction as the wheels and prevent the nose to lift...
Airwave is offline
Old 12-01-2018, 08:17 PM
Thanks I guess the owner must saw my ? Here. He has now explained the pro and cons and differences between the 2 guys. If you care to know go check it out. Thanks for the input though
Nerobro likes this.
