Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree91Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 02-28-2019, 07:16 PM
  #121
Trader Rating: 157 (100%+)
The O ring fits fine, you just have to take your time and work it into the groove in the adjuster nut. As far as the servo file the mounting holes close to the servo body then file the ears flush with the mount it's just that simple.
jeff jenkins sr is offline
Old 03-01-2019, 03:59 AM
  #122
Trader Rating: 19 (100%+)
I run a Sanwa SRG-HR in my Evo without any issues. Run the block in the short position.
I had the same issue with the spring retainer o-ring, it was a MAJOR pain to get installed.
iTz Nicholas72 is offline
Old 03-01-2019, 04:26 AM
  #123
tim fry's Avatar
Get this from Zen for your Sanwa servo https://www.zen-racing.co.uk/catalog/product_info.php/p12-evo-sanwa-servo-mount-p-3814
tim fry is offline
Old 03-01-2019, 05:32 AM
  #124
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Another option for mounting the sevo
sg1 is offline
Old 03-01-2019, 08:24 AM
  #125
Team EAM
I have a ton of those mounts in stock too! They do work awesome and drop some weight!!
EA
EAMotorsports is offline
Old 03-01-2019, 08:35 AM
  #126
AngryRog's Avatar
Trader Rating: 20 (100%+)
Where can I find nut inserts like this^^??
AngryRog is offline
Old 03-01-2019, 08:44 AM
  #127
EA
I'll have to pick one up whenever the Zoo Racing stuff comes in.
Wondering the same thing. In a sucker for some bling lol
Old 03-01-2019, 10:09 AM
  #128
Toyota Tom's Avatar
Originally Posted by Dog Bone
Still have the o-ring issue tho.
I don't use the o-ring.
Toyota Tom is offline
Old 03-01-2019, 11:57 AM
  #129
tim fry's Avatar
didn't have any issues just have to keep pressing it in the recess using the end of a driver and eventually it goes in
tim fry is offline
Old 03-04-2019, 03:37 AM
  #130
okx
Can someone mesure distance between screw holes on lower arm on roche p12?
Iím just thinking of using xray x12 lower arms on roche p12 carbon chassis and not shure is it possible...
okx is offline
Old 03-12-2019, 03:56 PM
  #131
Dog Bone's Avatar
I get 38.87mm, or 1.530" - I measured from the leadering edge of the back screw to the leading edge of the front screw on the chassis bottom; I didn't explicitly check, but I think the arm hole spacing is the same.
Dog Bone is offline
Old 03-14-2019, 04:19 PM
  #132
Some goodies for the P12 Evo 😍
RBLove, EAMotorsports and AngryRog like this.
Old 04-06-2019, 05:18 PM
  #133
EDWARD2003's Avatar
I picked up a P12 Evo and everything went together nicely except the front steering tierods. The ballcups and pivotballs are incredibly tight and is creating a lot of friction.
Is this normal?
EDWARD2003 is offline
Old 04-08-2019, 09:28 PM
  #134
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I built up 3 kits. About half of the front ball studs were snug. Give them a few gentle squeezes with needle nose pliers. If they were sloppy, guys would have even more of a fit! At least you can tune "snug".
Slapmaster6000 is offline
Old 04-08-2019, 11:35 PM
  #135
Trader Rating: 10 (92%+)
Is this normal?
a little, try xenon rde-0043, you will never use a regular ball cup again.
Johnny Carey is offline
