Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree71Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 02-07-2019, 09:14 AM
  #91
I don't have the car or servo with me, but the dimensions on the expert 3301 are: Dimensions: 33.6x15x29.5mm
  • Weight: 40.5 g
  • Speed:
dyoung is offline
Old 02-07-2019, 09:55 AM
  #92
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
  • Weight: 40.5 g
  • Speed:
Please search.. already discussed
https://www.rctech.net/forum/showpost.php?p=15370362&postcount=58
hanulec is offline
Old 02-07-2019, 06:59 PM
  #93
Trader Rating: 19 (100%+)
its the expert 3301. It sits too far forward and hits the steering rack. I tried flipping it around and couldn't get it any better. I picked that servo as I saw others had used it without issue. I saw another posting saying you have to purchase parts from a 2017 kit to make it work but hopefully that is not the case.
Thx
iTz Nicholas72 is offline
Old 02-09-2019, 11:44 AM
  #94
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I've mounted 3 Xpert 3301's, all slip right in.
Slapmaster6000 is offline
Old 02-12-2019, 06:21 PM
  #95
Just waiting on solder so I can finish wiring it up...
dway100 and JC3 like this.
Old 02-12-2019, 06:38 PM
  #96
protc3's Avatar
Originally Posted by chris moore View Post
Thanks Tom, I was assuming .05 for the pitch also but just not completely sure.
a standard m3 screw has a pitch of .5 buddy.
protc3 is offline
Old 02-17-2019, 03:55 PM
  #97
Just to check
What height spacers do end up adding to the front rear suspension on a tyre diameter of 41.5 front and 42.5 rear to get a ride height of 3.4mm front 3.6mm rear?
Smoking motor.. is offline
Old 02-17-2019, 05:03 PM
  #98
Dog Bone's Avatar
I see that some people *cough* Brian *cough* are running with only one damper tube. I've never tried this - I take it you have to increase the weight of the oil, and that's about it for setup changes?
I would have expected that the way the tube behaves on compression would be different than un-compression, but I have to assume that this is not the case?
I've just ordered a P12, and I'm looking forward to getting my hands on it here in about a week.
Dog Bone is offline
Old 02-17-2019, 09:39 PM
  #99
I am thinking about getting back into 1/12 scale after many years away from it. I just started running the F1 Evo and am leaning towards the P12 evo as well. I will have to order parts since my LHS doesn't carry Roche and plan to carry extra front lower and upper arms plus steering knuckles and king pins in my pit box. The one part that I'm not finding anywhere online is the plastic piece on the outside of the lower arm. Are they available anywhere? I tried to find a manual online for the new car to get part numbers, but I can't seem to find that either.
dway100 is offline
Old 02-18-2019, 12:11 AM
  #100
Trader Rating: 10 (92%+)
http://site.petitrc.com/reglages/roc...Evo_Manual.pdf
Johnny Carey is offline
Old 02-18-2019, 03:52 AM
  #101
Originally Posted by Johnny Carey View Post
thanks
dway100 is offline
Old 02-18-2019, 04:16 PM
  #102
Running 1 tube is no different feeling then 2 tubes. It's easy to over think it's effect. The reason 1 tube is used is because its common to run 10k or 15k with a spool on black. With dampening that light, in order to get the same effect in 2 tubes, you'd run 5-7K. It runs out of the tube causing it to be rebuilt more frequently. So....1 tube, twice the oil weight, half the work, same effect.
Old 02-18-2019, 04:23 PM
  #103
Originally Posted by Smoking motor.. View Post
Just to check
You would probably need just another .25mm shim additional to what the kit comes with in the front (which is a .5 and 1.0) and you'd likely need the .5 rear carrier plus 4 x .4mm shims sandwiched under it. Its pretty easy shim adjusting.
Old 02-18-2019, 05:50 PM
  #104
Ran my Evo for a few practice runs yesterday since the other 1/12 guys flaked out.
The car is very very very easy to drive.
Made a few changes that helped on SCRC's tight-mixed layout. Lots of hard 180s which I struggle keeping the car from binding too much in the turn.
Going up to 35wt oil and running the shock in the shortest position on the servo mount and top deck. Hopefully that will make it drive more out of the turn.
Old 02-18-2019, 07:55 PM
  #105
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
tried glueing the rears? Worked for me in gt12
Marcos.J is offline
