Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree71Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 01-03-2019, 04:19 PM
  #46
Trader Rating: 15 (100%+)
Have you had problems with ESD in the past or is the grounding strap just for piece of mind?
crisis641 is offline
Old 01-03-2019, 05:16 PM
  #47
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
a ground wire is necessary on every brand of ESC (but Tekin) for 1s applications on 'black' CRC carpet.
esc otherwise experience brown outs
hanulec is offline
Old 01-03-2019, 06:54 PM
  #48
Will the new front end bolt directly onto the 2017 USA Spec aluminium chassis? Is there any advantage to doing such a change?
Juniorabca is offline
Old 01-03-2019, 07:21 PM
  #49
hanulec's Avatar
Yes
Advantage... Tbd.
The Evo front end is a Roche only design.
Juniorabca likes this.
hanulec is offline
Old 01-03-2019, 07:48 PM
  #50
Would someone be willing to explain what exactly this means .... or maybe link a thread that I can read about it. I dont believe anyone at our club has had brownouts, and I've not yet heard of a ground wire. Thanks
ChadBlanton is offline
Old 01-03-2019, 07:56 PM
  #51
hanulec's Avatar
https://www.rctech.net/forum/electric-road/37-1-12-forum-3067.html#post15065368
corallyman likes this.
hanulec is offline
Old 01-03-2019, 09:09 PM
  #52
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Originally Posted by AngryRog View Post
O-rings on axle?
Lets just say there are a few things that "I" do. The o-ring is a new test for blowing out bearings on Click-Trac. The Roche o-rings are fairly rigid, lay an axle shim against and it makes for a nice bearing cushion. Will it save me from clipping a corner at warp 9 to the outside wall and DNF'ing a round/main??? It's worth a try. But if your'e pro-level, you don't need the o-ring. I'm building a car for 3.5 mod on snug Click-Trac next week. But if you'd like to try this, you do need to sand some of the spool side shim and the clamp hub to get 172...not harmful stuff.
As for grounding, an ounce of prevention cost far less then a DNF and a speed control. Static discharge seems to be more a "new carpet" issue. Give any of the new black tracks a couple of months to relax and discharge and it becomes a non-issue. But why risk it? The guys up north rub a rag sprayed with Static Guard on the bottom of the chassis occasionally. Some of the newer esc's are building in protection.
AngryRog likes this.
Slapmaster6000 is offline
Old 01-05-2019, 02:53 PM
  #53
I run a ground to the chassis and a ground to the screw that holds the motor. If I don't my hobbywing esc shuts down 2 laps in the run.
rezin is offline
Old 01-06-2019, 06:16 AM
  #54
Trader Rating: 65 (100%+)
I see ground strap “tuning kits” being sold in the not too distant future.
Like the ground strap kits all the Honda fast and furious guys get for their 110hp civics.
Its worth a 1/10 in the quarter so their times are now 16.5 seconds at 75mph through the traps.
Killin it!!!!!
Antimullet is offline
Old 01-06-2019, 09:46 AM
  #55
CW22's Avatar
Trader Rating: 107 (100%+)
Default P12 Evo
I liked the way the car handle, good chassis.
LAGuy, hanulec, AngryRog and 1 others like this.
CW22 is offline
Old 01-06-2019, 11:37 AM
  #56
AngryRog's Avatar
Trader Rating: 20 (100%+)
...and with virtually no setup. Haha. His car was very good.
AngryRog is offline
Old 01-07-2019, 08:05 PM
  #57
What servo is a good choice? My Xpert 3301 doesn't seem to fit. Thanks!
LAGuy is offline
Old 01-07-2019, 08:22 PM
  #58
hanulec's Avatar
Go back one page... Brian posted about his p12 with that servo
LAGuy likes this.
hanulec is offline
Old 01-07-2019, 11:29 PM
  #59
LAGuy, The red cube installs two ways...there is a little chamfer in the upper corner, that needs to face towards the rear of the car. Should drop right in.
bb
LAGuy likes this.
Old 01-08-2019, 12:35 PM
  #60
simple's Avatar
I'm interested in feedback on the plastic front lower arm ball holders and how they stand up to front end impacts. I've had other kits that sported a similar design and the results were mixed.....Xenon plastics are favorable, so I am waiting to see some reports.
simple is offline
