Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree91Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 12-21-2018, 12:24 AM
  #16
Trader Rating: 157 (100%+)
When's the next batch coming in another month or so?
jeff jenkins sr is offline
Old 12-21-2018, 02:12 AM
  #17
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Early Jan...
But 1/3 of what arrived was bought by dealers... So many unsold kits exist...
Dealers who bought kits are-
Canada/Ontario:
* Hyper Hobbies
https://www.facebook.com/hyperhobbies2014/
USA/Florida:
* Michael's Hobbies
https://www.facebook.com/michaelsrchobbies/
USA/Hawaii:
* ApexRC.com
USA/Minnesota:
* Genesis RC Raceway
https://www.facebook.com/Genesis-RC-Raceway-Products-12534…/
* Dollar Hobbyz
https://www.facebook.com/DollarHobbyzRC/
USA/New York:
* 360v2
https://www.facebook.com/360v2/
USA/Tennessee:
* APEX Raceway and Hobbies
https://www.facebook.com/APEXRaceway/
hanulec is offline
Old 12-21-2018, 09:09 AM
  #18
Old 12-25-2018, 08:21 PM
  #19
Trader Rating: 24 (100%+)
Will the P12'17 screw kit work for the EVO car? If so...what one would everyone recommend? I ran the Ti/Al kit in my last car, but is anyone using the all aluminum one?
fenton06 is offline
Old 12-25-2018, 08:41 PM
  #20
hanulec's Avatar
​​​​​​I used a Hiro seiko p12-2017 ti screw set and Xavier used the roche red aluminum screw set. Both offer enough screws to build out the car with some to spare...
hanulec is offline
Old 12-27-2018, 09:26 AM
  #21
Toyota Tom's Avatar
Default Weight
Have you had a chance to weigh the new car (before having to add any weight to get to 730)?
Thanks,
Tom
Toyota Tom is offline
Old 12-27-2018, 11:08 AM
  #22
hanulec's Avatar
Thanks,
Tom
Honestly there are a lot of factors driving car weight - electronics, body, tires
I had to add 6g to make weight.... I was happy with that
hanulec is offline
Old 12-27-2018, 01:43 PM
  #23
Toyota Tom's Avatar
I agree. Thanks for the reply. It is what I thought after reviewing the manual.
Tom
Old 12-27-2018, 04:39 PM
  #24
Default Tire size
What Diameters are you guys cutting to for MED - HIGH grip black CRC carpet?
Thanks in advance
wrutherf is offline
Old 12-27-2018, 05:16 PM
  #25
hanulec's Avatar
Thanks in advance
Three major variables
1. Foam type
2. Rim brand -- there are different sizes
3. Motor class
hanulec is offline
Old 12-27-2018, 07:33 PM
  #26
1. Foam type
3. Motor class
1) / 2) purple stripe - spec (CRC)
3) CanAM
wrutherf is offline
Old 12-27-2018, 07:40 PM
  #27
hanulec's Avatar
3) CanAM
Depends now on "one run" or multi runs. If one runs -- 39.5 or smaller front and rear
Most races are multi run so I start at 39.8 front and as large as 41.5 rear to drive a "larger" gear with fixed gearing. At the Halloween Classic I won on my 3rd run of tires started at this size.
hanulec is offline
Old 12-27-2018, 08:09 PM
  #28
Do the body mount all line up with the older car?
magnum is offline
Old 12-27-2018, 08:10 PM
  #29
hanulec's Avatar
Yes
hanulec is offline
Old 12-27-2018, 08:35 PM
  #30
magnum is offline
