Roche Rapide P12 Evo 1/12th Competition Kit
#152
ch indeed, however those little sacrificial plastic part on the end of the carbon arm are great. I've jut rebuilt the car everything else is straight and good to go. It cost me and upper arm, a turnbuckle and a lower pivot. We are talking full speed 3.5t boosted into a wall. I'll take that result any day.
#153
Just bought my first 1/12th scale car. Do these numbers on the bottom of the chassis have any particular significance?
#154
Front lower bulkhead
Building a p12 evo i notice the kit lower bulkhead and option lower bulkhead +1.5 version and i notice on some setup sheet some use the +1.5 bulkhead and some dont whats the purpose of the option bulkhead. Thanks for inputs
#155
Just makes the front wider and lowers camber gain. It's an essential for me in mod and 13.5 with a spool.
#156
As some have suggested, I've decided to run one side tube instead of two. I'm running 10K in the one tube. Checking tweak with both tubes installed the tweak was perfect. With one, the tweak was way off which I think makes sense given that your removing resistance from one side. When running one tube is it necessary to compensate for the missing tube by increasing spring pressure more than you would with two tubes?
#158
#159
Look out guys. Jc3 has ventured in to foam tire 12th scale wont be long now you'll be putting a 13.5 in that thing wanting to go fast. Lol.
#160
Battery fit.
Hello,
I build my P12 evo, stock setup.
I tried to fit the battery but it is touching the shock spring retainer and the nut under the upper pod plate.
Did anyone have the same problem or I missed something?
#161
Make sure that you have the 2mm spacer under the stud on the servo mount.
#162
#163
For the record, I was able to fit a Hitec HS-5245MG Digital Metal Gear Mighty Mini Servo on my chassis using a combination of the Roche large and standard servo mounts. I like the combination of specs and cost on this servo.
Price: $40!
Transit time: 0.12 sec/deg @ 6V
Torque: 76 oz/in @ 6V
Weight: 32g (1.12 oz)
Length: 32mm (1.3")
Width: 17mm (0.7")
Height: 31mm (1.2")
Price: $40!
Length: 32mm (1.3")
Width: 17mm (0.7")
Height: 31mm (1.2")
#164
#165
