Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree91Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 10-14-2019, 11:12 PM
  #136
CW22's Avatar
Trader Rating: 110 (100%+)
Hey Guys,
Is there an after market or Roche carbon chassis and rear pod replacement for P12 Evo to run on asphalt?
If it available, where can I get it?
Thx.
CW22 is offline
Old 10-15-2019, 12:28 AM
  #137
Originally Posted by CW22
Hey Guys,
Thx.
Bezerk RC in Australia have them. Bezerk RC
Remember the prices are in AUD, so possibly a bit cheaper than they seem
Scott_T is offline
Old 10-15-2019, 01:00 AM
  #138
antlockyer's Avatar
https://www.zen-racing.co.uk/catalog/product_info.php/rapide-p12g-evo-25mm-graphite-main-chassis-p-4074?osCsid=32d8b3e561f95ef68dfa4a1d113f6c3b
antlockyer is offline
Old 10-15-2019, 04:48 AM
  #139
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Roche released the Evo 12 G... Id recommend those carbon plates
hanulec is offline
Old 10-15-2019, 12:09 PM
  #140
Trader Rating: 15 (100%+)
Do you know if any of the US shops have the Roche graphite plates in stock?
crisis641 is offline
Old 10-15-2019, 05:07 PM
  #141
hanulec's Avatar
Will be here this week...
hanulec is offline
Old 10-31-2019, 04:11 PM
  #142
Will the carbon chassis plate make the car better on grey carpet?
Smoking motor.. is offline
Old 10-31-2019, 04:33 PM
  #143
hanulec's Avatar
Yes/no
The weight low is still probably better with alloy.. but carbon makes a great club car.
I remember Donny won 13.5 1/12 at Snowbirds with his carbon car on black rug....
hanulec is offline
Old 10-31-2019, 05:02 PM
  #144
For the most part carbon is more grip, aluminum is easier to drive. If grip is low enough then carbon becomes easier to drive because the aluminum doesn't make enough grip, skates around on the surface. I ran carbon at NYGP in stock because it's all I had with me and if was just fine. If it's just a club car for home the carbon isn't a bad thing, it doesn't bend like aluminum.
Racermac73 is offline
Old 10-31-2019, 11:38 PM
  #145
Yes/no
I am running on club nights at Chesterfield on grey carpet, it dosen't seem as easy to drive as on a permanent track such as MB models or Force raceway.
So I will try the graphite plates.
Old 11-01-2019, 02:03 AM
  #146
antlockyer's Avatar
I appear to have got 2 new Roche P12 Evos in preparation for the worlds
Ran one in 13.5 last week and couldn't believe how different it felt to my 2017 Roche and the Yokomos. Way easier to drive, way more corner speed. Pretty excited now.
Flygio likes this.
Old 11-05-2019, 11:05 PM
  #147
antlockyer's Avatar
Mod car nearly done
Stock
New race paint
Harold996tt likes this.
Old 11-08-2019, 09:08 AM
  #148
Default Side tube
Originally Posted by antlockyer
Mod car nearly done
Stock
New race paint
why do you run just one side tube ?
Duck999s is offline
Old 11-08-2019, 10:20 AM
  #149
hanulec's Avatar
One is enough
It's lighter
It allows better flow of wires to the pod
hanulec is offline
Old 11-10-2019, 10:50 PM
  #150
antlockyer's Avatar
Spent 2 days in Europe practicing in medium grip with the spool. Stock car is really good, so difficult to describe the feeling but the high corner speed is going to take some getting used to, it feels scary fast.
Open mod car I eventually went to a diff and went half a second quicker. Just too much power for me to be able to deal with with the spool. The diff feels like I can attack.
I did have a very large end of The straight incident, that's the second ever camber turnbuckle I've seen break, along with a bunch of other stuff.
Flygio likes this.
