Help with wet car build >
Like Tree17Likes
Old 11-16-2018, 03:14 PM
  #16
Speed Chaser's Avatar
Originally Posted by lifeofbrian View Post
Here in the UK there are official wet tyres. Sorex XG-Rain
Not cheap for me but they work pretty dam good for my fwd chassis in the wet.
Speed Chaser is offline
Old 11-16-2018, 04:45 PM
  #17
Billy Kelly's Avatar
Interesting. Unfortunately not available here in States. But trying a wet tire has me curious
Billy Kelly is offline
Old 11-17-2018, 02:29 AM
  #18
daveaustin5's Avatar
The tyres are great when it's wet, especially if there's standing water. They're super soft though so they don't last long if there's a lot of dry patches on the track.
daveaustin5 is offline
Old 11-17-2018, 03:43 AM
  #19
Roelof's Avatar
These tires are also used in 1/8 racing
https://www.kiss-tyres.ch/
Roelof is offline
Old 11-17-2018, 04:55 AM
  #20
gigaplex's Avatar
Are you sure they're Sorex? The ones I have here are labelled Schumacher/Shimizu.
gigaplex is offline
Old 11-17-2018, 06:05 AM
  #21
They’re labelled Schumacher/Shimizu but if you look at the sidewall they say Dunlop and some know them as Sorex
Daffs is offline
Old 11-17-2018, 06:53 AM
  #22
lifeofbrian's Avatar
I think Sorex is the name that Schumacher give them. In the BRCA rules they are called Sorex, wet and dry.
lifeofbrian is offline
Old 11-17-2018, 05:40 PM
  #23
skater-deez1's Avatar
Trader Rating: 75 (100%+)
Thumbs up
I'd go with the standard motor position, the mid makes the car more twitchy. It's good for really tight, technical layouts. I can't imagine it would have enough grip in the wet to work well. I'm still running 2 mi5's and a mi5evo, almost never run the mid configuration for any layout.
lifeofbrian likes this.
skater-deez1 is offline
Old 11-17-2018, 05:50 PM
  #24
One other advantage to the standard motor position would be that your rx and esc could be put into the same dry box as they are beside each other. In the mid motor set up your esc ends up behind the motor so you'd need two seperate dry boxes for the electronics as opposed to just one in front of your motor.
Old 11-18-2018, 12:52 PM
  #25
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
As an FYI Too, Ace makes some nice digital servos that are listed as waterproof!
1/8 IC Fan is offline
