Old 02-22-2006, 12:43 PM   #1
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Default IP3800's
what do you guys think of the IP3800's.
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 02-22-2006, 04:15 PM   #2
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Good all around cell.
The Ib's seem to yield better average voltage and runtime though.
The IP's are about the same having LOW resistance which is good.
Care is about the same as a IB as well.
I would be going to www.kinetixrc.com and getting a smoking deal on IB's.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 02-22-2006, 07:41 PM   #3
dakrat's Avatar
heres what i got using SEARCH http://www.rctech.net/forum/showthread.php?t=90594
dakrat is offline   Reply With Quote
Old 02-23-2006, 10:21 AM   #4
mainracer's Avatar
Send a message via AIM to mainracer
These cells are really good cells. I am in a good spot to talk about it because I had the chance to try both IP and IB because of some ''special rules'' at some races. For myself, I like the IP better, they are more consistent, they have a very low IR which is really good, and they have good runtime too.
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 02-24-2006, 12:50 PM   #5
xrayaustin's Avatar
Thanks for the info guys keep it coming
Old 02-24-2006, 01:05 PM   #6
Suspended
The best cells hands down...they are the same size as a gp 3300, just a tad taller the dia. is smaller..these cells rock...1.200 voltage 500+ run time ...no trays needed to make power...only use smart tray with these cells...
TeamHomies is offline   Reply With Quote
Old 02-24-2006, 01:09 PM   #7
xrayaustin's Avatar
why only smart tray.? why cant i use a integy 30 amp dischrger.
Old 02-24-2006, 01:19 PM   #8
Suspended
these cells CANNOT go beyond .9 cutoff....when the light goes out on the integy its to late...you better off taking the cells down to 5.40 on a turbo 35...than tray them to .9 on the smart tray before/after every run...the integy tray takes the cells down to zero way to fast...under .9 its like 6-10 amps thats way to much under the voltage threshold.....
Old 02-24-2006, 01:36 PM   #9
xrayaustin's Avatar
i use it on my ib38's though.......... what damage does it do to them if i do use it?
Old 02-24-2006, 02:20 PM   #10
Suspended
sooner or later your cells will drop off one by one....going beyond .9 will do the most damage to these type of cells....gp they can take way more abuse..
Old 02-24-2006, 02:42 PM   #11
The IB and IP are each designed differently and require a different type of maintence for long life and top performance. Does it mean one cell is better or will last longer....no not at all. Just that they are different and need to be treated in their own way.
Brian Anthony is offline   Reply With Quote
Old 02-24-2006, 07:25 PM   #12
xrayaustin's Avatar
so if after every run i put my battery on the smart tray that will be ok?
Old 02-24-2006, 09:37 PM   #13
You want to put the battery on the tray right before you charge it to equalize the cells. After a run discharge it down to 5.40.
Old 02-25-2006, 06:05 AM   #14
xrayaustin's Avatar
so before i charge put it on the smart tray and after i run put it on the turbo
Old 02-25-2006, 06:19 AM   #15
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Funny thing about these thoughts...
I bought a couple of practice packs from a guy that uses a novak flatline on his IB's before everyrun. They still take a good charge and run perfectly on the track.
XMSRacing is offline   Reply With Quote
Neglected IP3800's - need some batt experts to read this for me please. CaliberX Electric On-Road 13 04-15-2007 10:42 AM
Charging IP3800's w/old charger NoEffects6 Electric Off-Road 9 02-26-2007 02:45 AM
