Old 02-25-2006, 06:25 AM   #16
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Originally Posted by XMSRacing
Funny thing about these thoughts...
I bought a couple of practice packs from a guy that uses a novak flatline on his IB's before everyrun. They still take a good charge and run perfectly on the track.
Hes telling me why I cant use a integy 30 amp discherger on IP's and explaining why I should use a smart tray so my batteries dont take so much abuse.
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 02-25-2006, 06:45 AM   #17
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
oiy...
XMSRacing is offline   Reply With Quote
Old 02-25-2006, 12:51 PM   #18
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
With my IB3800s, I have been just putting them on the 0-30, then charging them back up. I havent noticed any loss in performance. I just got 3 packs of the IP3800s and was hoping I could treat them the same. What is it going to really hurt as long as I pull them off as soon as the lights go off.?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 02-25-2006, 02:24 PM   #19
XMSRacing's Avatar
someones point was that ib/ip cells dont "like" to go below .9 volts, which was why they dont recommend the 030 - it does not have an accurate cut off.
I dont know if I really believe that the cells dont "like" going below .9 for the simple fact that I have second hand cells from a guy that religously goes to 0 on his IB's.. and theywork just fine.
Old 02-25-2006, 02:54 PM   #20
The main thing that si going to be hurt by taking the IPs down so low is they will lose runtime with no gain in voltage or decrease in IR. This is only for the IP cell and that appears to be how it likes to be treated. I know that one matcher of IB recommends to use the 0-30 tray for all classes and other matcher of IB says to use the 0-30 for stock or 19t and a Novak tray for mod. It really depends on what works for you. I do know that the IP cells do lose runtime when they are droped below .9. I'm guessing over time the IBs would too but unless you run mod you would never really notice a drop of 20+ in runtime.
Brian Anthony is offline   Reply With Quote
Old 02-25-2006, 03:08 PM   #21
mainracer's Avatar
Send a message via AIM to mainracer
Like Brian said, IP cell loose runtime conciderably when they go below 0.9. I tested it when they first came out and I lost a lot of runtime and the voltage did not go up like on a GP cell. So using a tray that does not go below 0.9 is the best for these cell.
XMS racer: It does not make the batterie that bad, if you run stock you won't really notice it. but even in 19t you can see a difference at the end of the race. As I said, I had couple of pack that had been deadshorted and they were not that bad they were still strong but the batteries I run that did not go under 0.9 have a lot more runtime and are running better.
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 02-25-2006, 03:52 PM   #22
XMSRacing's Avatar
I dont have any of the IP's.. I was getting more at the comments of the IB's... I'm sorry I wasn't more specific!
I think one needs more then 4 hours of sleep to function.. I'm dead tired!
Old 02-25-2006, 04:38 PM   #23
xrayaustin's Avatar
I do run stock so you say I wouldnt notice a difference? I am so confused?
Old 02-25-2006, 08:39 PM   #24
In stock you don't use the full capacity of the cell. Meaning you come off the track after a run with runtime left. Because you don't use this runtime you can lose 20 secs of runtime it won't affect your run or on track performance as you don't use that runtime when racing.
Old 02-28-2006, 08:04 AM   #25
Bottom line is the IP cells perform! They are a great battery and when taken care of will produce great power charge after charge. I have packs from the very first batch and they still work great. The latest batch has been outstanding so far as well. You will not be dissapointed if you use IP batteries.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 02-28-2006, 12:32 PM   #26
xrayaustin's Avatar
The only reason I was wondering is because my new sponsor only provides IP's and I didnt know how to take care of these cells.
Old 02-28-2006, 12:38 PM   #27
go to teampoleposition.com and you will find all the best maintenance advice from the guy who brought IP's to North America.
Who is your sponsor out of curiosity.......
Joe
Old 02-28-2006, 12:57 PM   #28
xrayaustin's Avatar
Who is your sponsor out of curiosity.......[/QUOTE]
RC Professor
Old 02-28-2006, 03:42 PM   #29
DCARD's Avatar
Austin, You will receive an IP3800 Maintenance Guide with your batteries. They are different than the IB or GP cells. IP's DO NOT like to be discharged down to 0. If you want to use your 0-30 make sure you watch it, and as soon as the lights start to dim take your pack off the tray. If the lights go off
you just lost a ton of run time trust me. You will have no problem using thes packs two times a day. Just make sure you give ample time for them to cool
2-3 hours.
DCARD is offline   Reply With Quote
Old 02-28-2006, 03:51 PM   #30
Do you have to let cool after each step? If I repeak right before a round, they are gonna get warm. Should I time this so they are cool before I run them? Or is the main wait between discharging and charging?
Joe Cude
Neglected IP3800's - need some batt experts to read this for me please. CaliberX Electric On-Road 13 04-15-2007 10:42 AM
Charging IP3800's w/old charger NoEffects6 Electric Off-Road 9 02-26-2007 02:45 AM
