Widen front track at hinge pins or wheel hub difference and effect >
Like Tree2Likes
  • 2 Post By mleemor60
Old 11-06-2018, 06:18 AM
fat500's Avatar
Trader Rating: 33 (100%+)
Default Widen front track at hinge pins or wheel hub difference and effect
What would be the difference between using suspension blocks that make the front wider as opposed to using narrower blocks and widening the front at the wheel hub using Hub spacers thanks for your replies guys
fat500 is offline
Old 11-06-2018, 06:36 AM
LzREngineering's Avatar
Both ways will affect your suspension geometry differently. Widening the inner lower hinges will give you less camber gain and also affect your spring rate (shock angle will change). Widening the axles will lower? the roll centre and make the suspension softer.
LzREngineering is offline
Old 11-06-2018, 07:22 AM
mleemor60's Avatar
Trader Rating: 28 (100%+)
Not to mention changing the scrub radius.
mleemor60 is offline
Old 11-06-2018, 02:55 PM
fat500's Avatar
TKS what is the scrub radius? The push radius?
fat500 is offline
