Single belt TC, any advantage? >
Like Tree20Likes
Old 11-05-2018, 09:12 PM
  #31
mac853's Avatar
Could someone would agree what it said, "more linear feel"?
BD7 Spice - Yukinori Kagayama - TITC - Bangkok - 16-19.02.2017
mac853 is offline
Old 11-05-2018, 09:25 PM
  #32
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I would had brought the Spice conversion but I wanted the 40T diff pulley conversion...
OVA is offline
Old 11-05-2018, 09:47 PM
  #33
mac853's Avatar
To be honest, I met a guy in Yatabe Arena few weeks ago, and he shows me a similar car with this conversion kit.
His car uses 40t/20t pulleys with bd7 2015 bulkheads added SMJ BBSS shock tower, instead using main parts of 2016, about belt I doubt is ta07, didn't remember about all details, sorry!
That's why i asked about single belt cars.
Unfortunately this kit could only find inside of Japan
mac853 is offline
Old 11-05-2018, 10:16 PM
  #34
OVA
OVA's Avatar
I have the BD7 2015 and I didn't think the conversion belt is longer enough for 40t diff pulley
OVA is offline
Old 11-05-2018, 10:35 PM
  #35
mac853's Avatar
As I said he probably used ta07 belt, but not sure due we have communication problem
mac853 is offline
Old 11-06-2018, 01:52 AM
  #36
OVA
OVA's Avatar
catch ya...ty
OVA is offline
Old 11-06-2018, 02:59 AM
  #37
Skiddins's Avatar
To answer the original question...
A single belt design is less efficient as the belt has to 'flex' in both directions.
If it was a better design, everyone would be using instead of having moved away from it.
It also means the belt has to run down the centre line of the car so the motor is moved further out, again that's a step backwards.
mac853 and gigaplex like this.
Skiddins is offline
Old 11-06-2018, 04:09 AM
  #38
mac853's Avatar
You are right, if single belt is really convenient then why mostly people keep use 2 belts?
But of course i am looking for if it has little advantage for blinky.
mac853 is offline
Old 11-06-2018, 01:58 PM
  #39
That's not right. If you put the spur on the far side, and the motor on the near side, you can put the motor further towards the center of the car. Amusingly, this is a choice that team associated went for, while retaining the dual belt setup, this year.
Nerobro is offline
Old 11-07-2018, 12:40 AM
  #40
Trader Rating: 22 (100%+)
Default Kx1
Originally Posted by JoeyE View Post
Kyosho KX-One also had a single belt car......it sucked. Too much flex everywhere. And I still have it. TOP Racing has a conversion for one of their cars but where did that company go?
do you still have it?
can you send pictures Iím interested in purchasing the kx-one and any parts you might have for it.
Email [email protected]
5thscaleracer is offline
Old 11-07-2018, 02:37 AM
  #41
Skiddins's Avatar
No, that just changes the position of the pinion on the motor shaft.
If the main belt is central, no matter what you do, the motor *must* be further out as the motor mount and belt position are the limiting factors.
Skiddins is offline
Old 11-08-2018, 08:03 AM
  #42
Originally Posted by Xpress View Post
A single belt car has both the front and rear spool/diff driven with only a single belt wrapped @ halfway around the drive/layshaft pulley. A two belt has both the front and rear belts wrapped @ halfway around the drive/layshaft pulley(s).
This is only partiqlly true, most of single belt designs wrap more than half of center pulley, which increases contact area. Also, torque doesn't split 50/50, rear axle transmits more force during acceleration, front during deceleration
but if spur is between belt and motor, you have to move motor away from belt to make space for spur. With spur on other side, motor can be closer to belt.
Nerobro likes this.
Papi is offline
Old 11-08-2018, 08:49 AM
  #43
JoeyE's Avatar
Trader Rating: 45 (100%+)
I wonder if it will fit on a 2015....?
JoeyE is offline
Old 11-08-2018, 03:02 PM
  #44
OVA
OVA's Avatar
From my understanding from MAC853 was saying there was a person in Japan had 40teeth pulley with 2015 bulkhead with TA07 belt..!
mac853 likes this.
OVA is offline
Old 11-08-2018, 04:04 PM
  #45
Speed Chaser's Avatar
I been checking out the yokomo conversion, may have to get it. Looks like a good design.
Speed Chaser is offline
