Closed Thread
Old 02-21-2006, 12:34 PM   #1
Default Platinum or copper
Hi,
should I buy platinum plated, or copper battery solder bars? Platinum plated are 2x as expensive...
D_o_S is offline
Old 02-21-2006, 12:52 PM   #2
Send a message via AIM to rcguy2477
Just get whichever one is cheapest. The resistance of the bar has an extremely small % of the total resistance of the pack.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline
Old 02-21-2006, 01:49 PM   #3
jw92656's Avatar
Smile
I agree. Go with whatever is cheaper. Actually silver has the least electrical resistance, next is copper, and gold is the last. You can find silver bars for about the same price as the copper. I would only use platinum if my touring car had spinners too :-)
jw92656 is offline
Old 02-21-2006, 02:01 PM   #4
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by D_o_S
Hi,
I think the copper bars are easier to solder on , they seem to transfer heat better.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline
Old 02-21-2006, 03:37 PM   #5
Are you serious. Why do you think companies use gold and sometimes platinum plating on expensive circit boards.
Vahe is offline
Old 02-21-2006, 03:47 PM   #6
May have something to to with corrosion but the order of resistance best to worst as follows:
silver
copper
gold
aluminum
tungsten
iron
steel
platinum
As was stated earlier the distance in battery bar is so the resistance is minimal.
Lano is offline
Old 02-21-2006, 05:24 PM   #7
Super Moderator
Grizzbob's Avatar
silver
copper
gold
aluminum
tungsten
iron
steel
platinum
Exactly right. It's resistance to corrosion that makes a few materials desireable for this(that's why many people, including the military use gold for their electrical contacts, it seems to have the best balance of low resistance & high corrosion resistance). But for our purposes, copper or silver is just fine, so just go with what's priced best for you.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline
Old 02-21-2006, 06:14 PM   #8
EddieO's Avatar
R/C Tech Charter Subscriber
Guys, platinum is a HORRIBLE conducter......horrible. You are better off using a piece of wood....
Get the copper ones.....they are not only cheaper, but a superior conducter and much better at dissapating any heat....
Platinum is only used in electrical applications when they need to prevent corrosion and resistance is not an issue....
Later EddieO
www.teambrood.com
EddieO is offline
Old 03-15-2013, 04:46 AM   #9
Suspended
electricity is electricity and oxidation is oxidation. Neither of which care what the application is. If you are the one who wants the flashlight to work you want clean contacts. Copper is the better conductor when it is clean, however its impossible to keep it oxide free. Gold stays as a noble element unless put under some really hard conditions which is why every one plates contacts with it that they want to keep working for a lot of years.
Gold is much better over the long haul than oxidized copper and copper will oxidize plain and simple. Push current through it when its wet and bad things really start to happen. If you can keep it mostly clean and dry it will work fine
benlinus is offline
Closed Thread
need to make copper sunburst xtrememadness Painting, Designs, Graphics and Photography 0 04-20-2008 07:32 PM
F/S BRAND NEW Dynamite Platinum .21 SG Engine and Platinum 053 Pipe Nitroracer8 R/C Items: For Sale/Trade 23 03-03-2008 07:58 AM
Mini Copper or ...? Potter Electric On-Road 9 10-25-2007 02:08 PM
Non RC - 1in Diameter copper pipe Ashley Cobb Australia Wanted to Buy 2 09-27-2007 04:16 PM
Soldiering to Copper, Help!! doublest Electric On-Road 2 05-13-2003 09:23 AM
