Gizmo Racing USA Genesis TC Kit >
Like Tree530Likes
Old 01-07-2019, 03:22 PM
  #121
RoyB's Avatar
Trader Rating: 19 (100%+)
Is the steering rack in Genesis a Gizmo product or is it the Awesomatix BSSX?
RoyB is offline
Old 01-07-2019, 03:51 PM
  #122
CristianTabush's Avatar
Both. If you want to get a set, shoot me an email and I will get you one. We have some in stock.
Thanks!
RoyB likes this.
CristianTabush is offline
Old 01-10-2019, 02:00 PM
  #123
RoyB's Avatar
Ordered Genesis kit with awesomatix dif & Spool to run on asphalt this year. Will use GZ2 for the rest of carpet season.
Couple of questions.
Does anyone have a starting setup for asphalt?
Do you use the same shock towers for ulp shocks as stock shocks?
thanks Roy
RoyB is offline
Old 01-10-2019, 04:15 PM
  #124
CT posted this setup for asphalt Gizmo Racing USA Genesis TC Kit
For the ULP shocks, my understanding is that you would need different shock towers, CT can hook you up with that.
thanks Roy
Walers is offline
Old 01-10-2019, 04:23 PM
  #125
RoyB's Avatar
Okay, thanks, I somehow missed the setup when going through the thread.
RoyB is offline
Old 01-11-2019, 01:35 AM
  #126
Trader Rating: 27 (100%+)
thanks Roy
Hi Roy,
Good to hear you got your GZ2 on its way to getting dialed in. Ill dig up a setup I ran at Fresno that might be helpful for you. There is a different shock tower for the ULP shocks.See you at 209.
RoyB likes this.
MDawson is offline
Old 01-24-2019, 08:23 PM
  #127
Carpet track closed so will be running my aluminum chassis Genesis on Asphalt now.
What do you guys think I will need in terms of option items (VTD, PCS link, etc.) to get the alum. car running on asphalt?
Walers is offline
Old 01-25-2019, 06:57 AM
  #128
Honestly, pulling screws to help flex should be all you need in VTA.
Walers likes this.
Hopscotch is offline
Old 01-25-2019, 12:25 PM
  #129
Thanks!
Walers is offline
Old 01-25-2019, 01:27 PM
  #130
Our Aluminum chassis is fairly stiff, but it does not mean you cannot make it work. I know Larry Myers likes his car with an alloy chassis and a VTD. Myself, I like carbon chassis with regular top deck. PCS brace is a nice tuning option that most guys like as it gives the car a bit better forward bite and rotation. If you run the VTD, there is no need for PCS.
Another thing we have been doing is playing around with bulkhead screws for Flex. Look up our Gizmo Racing USA Team Driver Private page and I will add you there. We have some pictures of what I am talking about it there.
Walers likes this.
Old 01-25-2019, 03:51 PM
  #131
Thank you, want to give the VTD a try.
Walers is offline
Old 01-25-2019, 11:26 PM
  #132
foampervert's Avatar
Is it got manual?
foampervert is offline
Old 01-26-2019, 08:21 AM
  #133
The manual is almost done. Should be done pretty soon. At the moment we are using a combination of the GZ2 manual and an a800 manual to get it done as well as some pictures on our website.
Walers likes this.
Old 01-26-2019, 08:29 AM
  #134
Trader Rating: 176 (100%+)
Originally Posted by foampervert View Post
Is it got manual?
Also I will be doing some videos on my facebook page this week, if you dont have me added as a friend you can message me on here and ill get you added. Im not sure how in depth, or how far ill be able to get into the videos but itll be a nice set of videos for someone.
RoyB and Walers like this.
thecaptain is offline
Old 01-27-2019, 07:18 PM
  #135
We Just released a bunch of new option parts for the Genesis.
Long Arm and V2 Hub Conversion
V2 Spool Conversion
V2 Diff Conversion
2.15 Spring
2.35 Spring
2.55 Spring
ULP Front Tower
ULP Tower Rear
The Long Arms, contrary to typical long arms actually make the suspension softer due to the increase in length between the lower shock pivot and outer pivot. The tire is more supported, the scrub radius is decreased and the results are a smoother car with more stability, more steering and more corner speed. The long arms were used by Eric Albano and Mark Dawson to TQ and Win the 17.5 Rubber and 17.5 Foam Classes at the 209 Carpet Challenge this past weekend.
Even though the race was on gray low-medium bite carpet, we really do think these will provide good results in really high bite conditions as it will make the suspension act softer and will allow us to use a little more aggressive settings on our Genesis TCs.
RoyB, WagwanBumba and Walers like this.
