Gizmo Racing USA Genesis TC Kit
#106
As long as you got it on there, you should be ok. However, one tip, if the arm is too thick, you should be able to lap the whole thing on some 600 grit and then finish with some 1200-2000 wet sand to get smooth finish to get the arm down to the thickness needed. I am not going to say this is the reason for matte finish arm, but it is an advantage that it is this way.
I have never heard of carbon swelling, but it could be quite possible that some tolerances are slightly different on the older production of shock mounts and across the A-Arms. Get some material that is 0.1mm thicker and a mount that is 0.1mm narrower, and there can be some issues sometimes.( 0.1mm on all items is standard high-quality tolerance in our industry). I have some on my car and they were a bit tighter than the newest batch ones, but they still slide on.
Regardless, if the items you feel are bad, send them back and I will issue replacements so long as they have not been damaged.
I went through all the arms sent to me including the extra ones I bought and their measurements varies with ones as thick as 3mm and as thin as 2.8mm. At least its good to know its not a manufacturing problem.
Another thing while talking to Dave, how do we measure caster with this setup now? Before when using the AMX hubs we could easily mount the caster gauge, but now theres nothing to mount to.
#107
Paragraph 6 on comment #546 of the GZ2 Thread explains how to measure caster on the new aluminum knuckles.
Gizmo Racing GZ2!!!
Gizmo Racing GZ2!!!
#111
yes, the camber plates do work, but they are 1 pc. So when used with the low profile top deck, it must be spaced up 3mm or at least be combined with some of the Genesis Bulkead brace +1mm of shims. (this is probably the best plan of action.)
We don't have upgrade kits because we are out of hubs. But once we get more hubs in stock, we will make the upgrades available again. I know I have about 10 or so upgraded cars out there that use the new hubs, inset battery and all related parts.
#117
Nice I need a set also,I here there is some Great News coming from the Gizmo Camp.
#118
Yes I will be making one for the other side as well. Still fine tuning the needle as it seems a bit flimsy right now and Im not too happy about the print quality on the hub. I dont plan on selling these, but if you want I can give you the STL file and you can have it printed out either by someone with a 3D printer or shape ways
Fair enough. I never tried measuring caster that way so it is unfair for me to say the process is a guesswork.
Thanks, Like I said, Im not planning on selling these, but files are available if you want and you can have it printed out however you like.
