Gizmo Racing USA Genesis TC Kit >
Like Tree520Likes
Old 10-22-2018, 11:22 AM
  #31
Trader Rating: 176 (100%+)
Originally Posted by The Teacher View Post
thecaptain, were you using the Genesis with the alloy chassis? Did you run the car with alloy or graphite arms? Last, did you run the low ball for the arm mounts or the stock balls?
As CT had said, carbon arms, the new arms are super beefy, but as light as the alloy arms, and dont bend at least with a few good hits they didnt. Alloy chassis, I will be running the low balls all the way around from now on, however for that particular race, I did run the high balls in the rear of the car, however it was better afterwards with the low balls. Ill get a setup posted today something soon.
Marcos.J and RoyB like this.
thecaptain is offline
Old 10-22-2018, 01:52 PM
  #32
Here is the set up I ran on Genesis. If you have any questions please ask. This was for medium grip track, that was relatively tight, on a 100x50 size track. Ill let you guys know how it works on a medium bite 36x60 track as well..
Ty-bo likes this.
Old 10-25-2018, 10:27 AM
  #33
arn671's Avatar
Trader Rating: 16 (100%+)
Have a GZ2, is there a conversion kit available to get it to the Genesis kit?
arn671 is offline
Old 10-25-2018, 10:34 AM
  #34
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
[QUOTE=arn671;15323378]Have a GZ2, is there a conversion kit available to get it to the Genesis kit?[/QUOT
OVA is offline
Old 10-25-2018, 10:36 AM
  #35
OVA
OVA's Avatar
thats would be nice
OVA is offline
Old 10-25-2018, 11:27 AM
  #36
I know there is a conversion from the Beta to Genesis. The differences from Genesis to the GZ2 are numerous. The drive train is completely different, as well as the suspension, and chassis, as well as motor mount/servo mount, and steering system. In short it would be possible to convert your GZ2 to Genesis, but youd have 80% of a GZ2 left over. Youd be better off updating the GZ2 to a GZ2 19, or purchasing a Genesis.
disaster999, Marcos.J and RoyB like this.
Old 10-26-2018, 11:59 AM
  #37
I'm starting to see the light on the Genesis now. I underestimated this C.T. guy to be honest.
DavidNERODease is offline
Old 10-26-2018, 01:15 PM
  #38
CristianTabush's Avatar
This.
We can make you anything as long as you are willing to wait enough time (usually about 2 weeks for something custom). However, the issue is that the conversion would be close to $500.00.
I usually try to have a path to upgrade in between generations. However, the upgrade path to the Genesis was via the Beta, which was the upgrade from the GZ2. Upgrading from essentially 2 gens back is tough. I will say though, the "2019" conversion for the GZ2 is nice, and won't break the bank. I'll have some pics as soon as I build me a new one over the next week or two.
CristianTabush is offline
Old 10-27-2018, 08:22 PM
  #39
Had a killer testing day today at the track. This was the first time I got to run the car in full Genesis, non prototype spec.
What a pleasure it is to drive. It does everything the prototype did, but better. The VTD was great in the mod car. The car was so stable and composed, with plenty of steering even though I never ran brand new tires on it. On the stock car I ran the fastest times I had done at Porter on a day where the grip was less than ideal. The car had sooo much steering. The new motor mount was super awesome and adjusting it allowed me to fine tune the rotation of the car really well.
I ran PSS shocks on both cars. Started with the SLP length in the stock car and ULP in mod. I ended up swapping them and ran like that the rest of the day. The SLP gave much more steering and rotation than the ULP, so they worked well with the VTD car. ULPs were so tame and stable, it was actually really surprising.
I'll post a set up tomorrow with a good starting point for asphalt.
MDawson, Marcos.J, tbrymer and 3 others like this.
Old 10-28-2018, 05:33 PM
  #40
Trader Rating: 26 (100%+)
Even the Genesis likes precision.
MDawson is offline
Old 10-28-2018, 07:11 PM
  #41
Here is the set up that I ran. Please feel free to ask questions.Porter Test day
MDawson and Marcos.J like this.
Old 11-04-2018, 07:50 PM
  #42
Default Building Gear Diff
I see that for the gear diff you used 7k oil; Is that for the GD2 or the stock Gizmo gear diff?
Walers is offline
Old 11-04-2018, 08:26 PM
  #43
Stock gizmo diff. For smaller corners i prefer 5k
Walers likes this.
  #44
Zac uses the AMX diff.
Usually with the Gizmo diff 3-5k for spec classes, club racing and 7.5K for mod, club racing is about where you want to be.
Thanks!
Walers likes this.
Old 11-04-2018, 08:35 PM
  #45
Where does these O-rings go? Measured and itís like 9.5x2mm. It does not look like 8010ís nor 8020ís. It came with the gear diff bag.
Walers is offline
