Gizmo Racing USA Genesis TC Kit >
Like Tree530Likes
Old 08-06-2019, 07:45 AM
  #271
Default Side Effects
Originally Posted by thecaptain View Post
Before with the long arms we were running the ballstuds in the outer hole on the top and bottom. With the new arms, we opted to go with the outer hole on the bottom of the hub, and the top hole on the top of the hub. This is to create a wider track width, and a shorter upper camber link.
Does that answer your question?
I was asking because kingpin inclination has some significant geometry side effects which have to be accounted for when adjusting camber and caster - or maybe they don't if it turns out that those side effects make you go faster I guess I wanted to know if the intent was to add kingpin inclination for performance reasons but I guess in this case it's a consequence for different reasons - so yes that answers my question. Lap times have the final say.
DavidNERODease is offline
Old 08-06-2019, 07:55 AM
  #272
CristianTabush's Avatar
Originally Posted by DavidNERODease View Post
Is running kingpin inclination on the front recommended?
It's something I am just starting to test with and are liking so far. The car does feel more stable running mod on a large track. I still need to play around with running some extra caster to see if it actually makes a driving difference. I guess if we were to follow what should happen, it "should" give more in corner steering by moving some of the cornering load to the inner front tire, which also should conserve some outer front tires, (especially in mod asphalt) and fully exploit the advantage of the KPI (given that we adjust for some extra caster).
DavidNERODease likes this.
CristianTabush is offline
Old 08-06-2019, 08:01 AM
  #273
I will add that Awesomatix Hubs usually have a little positive king pin angle (depending on the amount of under the hub shims) and I could not tell much of a difference when going from negative to positive by playing around with shims. Ours is a little more drastic.
In the end, it's just stuff to try I guess. If there is one thing I always say is that there are many different ways to go fast.
glennhl and Walers like this.
Old 08-18-2019, 07:43 AM
  #274
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
I got 2 Genesis the other day one from a team driver , and I’m very impressed !! I ran one in usgt ,the car was untouchable in usgt! Had TQ and A-main win setting the fastest laps in the class. I was able to do a full lap at the same track from previous runs. I ran almost identical set up as Cristian’s asphalt set up just a minor change (1mm shim under the front and rear arms) .
my 17.5 had some goodies that Cristian sent me , flex aluminum chassis,flex cut top deck and also the long arm conversion with the new hubs . The car was very fast and carried a lot of corner speed. Had the layshaft screw come loose in the main fighting for 3rd.
Thanks again Cristian for the hop-ups!!
Ggrant, Walers and Bry195 like this.
Marcos.J is offline
Old 08-18-2019, 07:59 AM
  #275
Brian10811's Avatar
I was very impressed with both of Marcos's Genesis cars. I am thinking about buying the new Genesis for my 2nd class in the future. Next week I will give one a spin around the track. I think the Genesis was holding the fastest corner speed of any car around the track. It was very impressive all the way around the track.
Marcos.J likes this.
Brian10811 is offline
Old 08-18-2019, 08:45 AM
  #276
Super Moderator
Marcos.J's Avatar
thanks Brian fun day for sure :
Marcos.J is offline
Old 08-18-2019, 08:46 AM
  #277
Super Moderator
Marcos.J's Avatar
Walers likes this.
Marcos.J is offline
Old 08-18-2019, 04:06 PM
  #278
Super Moderator
Marcos.J's Avatar
started off with CT's set up and just a few changes to fit my driving I guess lol)
Marcos.J is offline
Old 08-19-2019, 07:58 AM
  #279
YBSLOW's Avatar
Ran my midmotor car this weekend and improved my personal best time by 6 seconds 1st night out with it. Generally easier to drive fast. In mod of course as 17.5 is always easy to drive with any setup.
Marcos.J, Ggrant and Brian10811 like this.
YBSLOW is offline
Old 08-19-2019, 08:04 AM
  #280
lorider75's Avatar
I’ve been saying it since my gz2, the gizmo cars are the best in the business. It’s a better amx in my opinion. I can’t wait to get my hands on the mid motor and the high angle shock system.
lorider75 is offline
Old 08-19-2019, 08:09 AM
  #281
Super Moderator
Marcos.J's Avatar
hope to convert both mine very soon
Ggrant likes this.
Marcos.J is offline
Old 08-19-2019, 10:31 AM
  #282
BOTH ? Lol lol u know u can send one my way right lol
Ggrant is offline
Old 08-19-2019, 11:16 AM
  #283
Trader Rating: 176 (100%+)
I hear that the 20/20, as is seeing the light for the first time :P, will be available really soon!
Marcos.J and Ggrant like this.
thecaptain is offline
Old 08-19-2019, 01:31 PM
  #284
Is there a plan to release a mid motor kit with long arms?
malkiy is offline
Old 08-19-2019, 02:28 PM
  #285
Super Moderator
Marcos.J's Avatar
As The Captain stated “soon”:
Ggrant likes this.
Marcos.J is offline
