Gizmo Racing USA Genesis TC Kit >
Like Tree530Likes
Old 01-27-2019, 07:48 PM
  #136
Regional Moderator
disaster999's Avatar
Any ETA on the diff for the Genesis? Still waiting for them in the mail.
Also the is V2 spool and diff conversion is for the AMX parts?
disaster999 is offline
Old 01-28-2019, 01:10 PM
  #137
RoyB's Avatar
Trader Rating: 19 (100%+)
Originally Posted by CristianTabush View Post
We Just released a bunch of new option parts for the Genesis.
Long Arm and V2 Hub Conversion
V2 Spool Conversion
V2 Diff Conversion
2.15 Spring
2.35 Spring
2.55 Spring
ULP Front Tower
ULP Tower Rear
The Long Arms, contrary to typical long arms actually make the suspension softer due to the increase in length between the lower shock pivot and outer pivot. The tire is more supported, the scrub radius is decreased and the results are a smoother car with more stability, more steering and more corner speed. The long arms were used by Eric Albano and Mark Dawson to TQ and Win the 17.5 Rubber and 17.5 Foam Classes at the 209 Carpet Challenge this past weekend.
Even though the race was on gray low-medium bite carpet, we really do think these will provide good results in really high bite conditions as it will make the suspension act softer and will allow us to use a little more aggressive settings on our Genesis TCs.
A lot of fun watching Mark and Eric. Their cars looked great on the track. A couple of other people became interested in the Genesis at the track.
Thanks to Mark for all of the help.
CristianTabush likes this.
RoyB is offline
Old 01-28-2019, 08:09 PM
  #138
CristianTabush's Avatar
The 3D printed parts have just arrived.
THe V2 spool and Diff Conversions are not for the AMX parts, they are the AMX parts and pieces necessary to install on the Genesis.
disaster999 likes this.
CristianTabush is offline
Old 01-28-2019, 08:10 PM
  #139
Trader Rating: 27 (100%+)
It is extremely helpful to have receptive drivers. I appreciate your questions and willingness to try different approaches. We'll continue to push!
RoyB likes this.
MDawson is offline
Old 01-28-2019, 08:21 PM
  #140
Regional Moderator
Thanks CT, cant wait to receive new parts. Finally ran the car with the updated parts and so far so good. It was a bit hairy with very old worn out ribbed tires but still very predictable and easily controllable.
Yeah, thats what I mean, bits and pieces needed to install the AMX parts onto the Genesis.
Old 01-29-2019, 07:21 AM
  #141
Larrysraceprep's Avatar
Ordered Genesis kit with awesomatix dif & Spool to run on asphalt this year. Will use GZ2 for the rest of carpet season.
Couple of questions.
Does anyone have a starting setup for asphalt?
Do you use the same shock towers for ulp shocks as stock shocks?
thanks Roy
Hereís what Iíve been running at n control
RoyB and Walers like this.
Larrysraceprep is offline
Old 02-01-2019, 02:27 PM
  #142
RoyB's Avatar
Kit is going together nicely.
Question about the new axles. What is the purpose of putting thread lock in the hole in ST116? will it help hold the pin in. Worried about it getting in moving parts. I use blue locktite and it is pretty runny.
RoyB is offline
Old 02-01-2019, 02:31 PM
  #143
Yes, it is supposed to keep the part in. Fwiw, I donít use loctite, I just keep well greased. I will say these drop out fairly easy if you pop something and the bone cones out of thr drive cup.
RoyB likes this.
Old 02-04-2019, 03:49 PM
  #144
I used thread lock and made a mess, ST113 was not moving freely. Grease would be my recommendation.
RoyB likes this.
Walers is offline
Old 02-08-2019, 05:51 AM
  #145
Default Mod
Almost ready for Mod...
thecaptain likes this.
Walers is offline
Old 02-13-2019, 11:59 AM
  #146
KINGZJ's Avatar
I scored a genesis on fleebay. WHat are the must haves for black carpet? The car appears to be very stock looking with a carbon chassis.
KINGZJ is offline
Old 02-13-2019, 12:02 PM
  #147
Trader Rating: 176 (100%+)
Really some tuning springs, aluminum chassis for sure. The new hubs are nice for castor doodles.
thecaptain is offline
Old 02-13-2019, 04:45 PM
  #148
tbrymer's Avatar
Damn, you got a deal on that.
tbrymer is offline
Old 02-13-2019, 05:11 PM
  #149
Regional Moderator
What new hubs?
you mean these?
http://gizmoracingusa.com/?product=lac001-gizmo-genesis-long-arm-conversion
Old 02-13-2019, 05:52 PM
  #150
What new hubs?
you mean these?
Im not sure if theyre available in another form. I got both together.
