Step charging and IB3800's >
Old 02-20-2006, 04:11 PM
Default Step charging and IB3800's
For 19 and stock touring.....has step charging seen any advantages over regular charging? thanx.
nomaak is offline
Old 02-20-2006, 05:43 PM
step charging is more for if you are running mod to gain more run time.
if you like give it a go & see if you like the results.
i still like the normal linear charge at 6.0 amp's for both stock & 19 turn.
flysti is offline
Old 02-21-2006, 01:10 AM
Hey, I could be wrong. What I heard that Ib3800"s are a finnicky cells. They prefer liniar charger at 6 amps. This is what I heard is best to keep the cells at top form.
cyrrus is offline
Old 02-21-2006, 02:05 AM
Step charging is not needed for IB cells.
Hagberg is offline
Old 02-21-2006, 04:18 AM
why not ?
Step charging is keeping the cell temp down.
Frans H is offline
Old 02-21-2006, 04:23 AM
Originally Posted by Frans H
why not ?
yes but ib's like to be warm as they perform better with a bit of heat in them. i.e more voltage.
step charging was built around gp cells
flysti is offline
Old 02-21-2006, 05:09 PM
lookinco's Avatar
I just did a simple test. I have two packs of IB3800 and I cycled them two times. The first time with step charge at 7A > 0.5A > 6.5A and the second time with 6a linear. I charge and discharge both pack with the ICE charger.
The numbers on the label are:
Voltage IR Runtime
1.198 2.0 399s
1.199 2.0 398s
1.198 2.0 398s
1.199 2.0 399s
1.199 2.0 399s
1.199 2.0 399s
The result is that with 6a linear charge, the pack have a higher Average volt and a lower IR.
Here are the numbers:
-------- Pack1 Pack2 (step charge 5mv)
AvG Volt 7.350 7.328
Resistence 29 27
-------- Pack1 Pack2 (6a linear 5mv)
AvG Volt 7.382 7.415
Resistence 28 27
With step charge, the peak temp of the battery is around 110 ~ 115F
With linear charge, the peak temp is around 120~122F
Both peaked with about the same capacity, around 4200mah
After first cycle, I discharge the rest of the pack on the team wave discharger until 0.9v per cell and store them until the next cycle. I then discharge them again on the team wave to 0.9v before I charge them again.
The numbers in the test might not be very accurate, but at least we could look at them and compare.
lookinco is offline
Old 02-22-2006, 06:13 AM
teamgp's Avatar
Voltage IR Runtime
1.198 2.0 399s
1.199 2.0 398s
1.198 2.0 398s
1.199 2.0 399s
1.199 2.0 399s
1.199 2.0 399s
Resistence 29 27
Resistence 28 27
I did this same type of test with my first set of IB3800's back in August on a CDR5000 and discharging at 30A. The results were very similar to what you found.
However, I also tried linear charges of 6.0A, 6.2A and 6.5A. At 6.5A, the voltage and runtime went down when compared to the 6.0A charge. But at 6.2A, the voltage went up a little with not much dropoff in runtime or change in IR from the 6.0A charge.
teamgp is offline
Old 02-22-2006, 06:34 AM
wo ...thx guys~!~~
those really a gd reference ar!!!
anyone tried for GP cells?
i just get 5 packs of GP3700~~
tsuiyuen is offline
Old 02-22-2006, 07:12 AM
jamescam's Avatar
Any heat problems charging at 6.2A? What peak detect did you use?
jamescam is offline
Old 02-22-2006, 07:41 AM
teamgp's Avatar
I'm using this rate now and have the peak detect at 05 or 06 on the MuchMore, depending on room temp. The packs are coming off the charger anywhere from 118-122F and rise another four to five degrees afterward.
teamgp is offline
Old 02-22-2006, 10:48 AM
Wait. What was the step that you used? You started high at 7A, then went low to 0.5A, then high again at 6.5A? Do any of the step chargers allow you to charge the first 1/3 of the charge at 3.5 amps, then the next 1/3 at 4.5 amp and the final 1/3 at 6 amps? I would be curious to see what that does as compared to a straight up 6 amp linear charge.
Motor City Hami is offline
Old 02-22-2006, 11:15 AM
lookinco's Avatar
On the ICE, the step charge function is very flexible. There are 4 stage that you could choose and is adjustable in every 100mah increments.
I used 7a > 0.5a > 6.5a because that is what in most step charging profile for the IB3800, including the Hara profile for the much more charger.
lookinco is offline
Old 02-22-2006, 11:22 AM
@lookinco: what was the time in days/hours/minutes to the next charge ?
My experiences are that the IB cells have better numbers on the second charge off the day !! whatever charge method in use
Frans H is offline
