Like Tree321Likes
Yokomo BD9
Old 03-02-2020, 06:19 AM
  #631
charlie63's Avatar
Hi guys, I've just buy Arrowmax medius kit for my BD9, I want to use also BD10-008FG and BD10-008RG suspension bottom arms………. are they fit on BD9 as well ? (better the graphite or normal ones ?) ...... anything else need to be changed ??
charlie63 is offline
Old 03-06-2020, 02:25 AM
  #632
charlie63's Avatar
Hi guys, please don't answer all together otherwise I can hardly understand ………
Old 03-20-2020, 03:25 PM
  #633
Yes, those arms will fit, Graphite is preferred. You should be gold even with just going with the long front arms and leaving the stock on the rear.
Realtek is offline
Old 03-23-2020, 03:36 AM
  #634
charlie63's Avatar
thank a lot ;-)
Old 06-20-2020, 09:08 AM
  #635
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Question about the RTC on BD9
does it make a difference compare the standard ?
thanks
OVA is offline
Old 06-20-2020, 05:25 PM
  #636
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
thanks
I ran it it was ok but was faster with the standard rear
Marcos.J is offline
Old 06-21-2020, 02:53 PM
  #637
OVA
OVA's Avatar
How did you like your Mid motor conversion compare the standard or stock chassis?
OVA is offline
Old 06-21-2020, 04:54 PM
  #638
Super Moderator
Marcos.J's Avatar
never ran the bd9 with the rear motor but I did have the BD8 rear motor . I like the BD9 mid motor a lot better ! I also converted it to the BD10 long arms and itís a huge improvement
Marcos.J is offline
Old 06-21-2020, 06:58 PM
  #639
mac853's Avatar
Excuse me, what kind of mid conversion are you running on BD9 with long arms?
mac853 is offline
Old 06-22-2020, 03:27 AM
  #640
Super Moderator
Marcos.J's Avatar
arrowmax you need to get the bd10 arms and toe blocks
Marcos.J is offline
Old 06-22-2020, 04:58 AM
  #641
Super Moderator
Marcos.J's Avatar
You need the new BD10 front and rear arms, na front rear blocks and the new na shims. Plus have A suspension blocks for ff, fr and rr. I also drilled a new hole in my medius chassis to accept the new na blocks.
Marcos.J is offline
Old 06-22-2020, 10:11 AM
  #642
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hey
Did you duplicated the new holes from BD10 chassis common to Arrow chassis?
I though the new hole was closer to the center allow to use longer arms?
Goingfast is offline
Old 06-22-2020, 10:54 AM
  #643
Super Moderator
Marcos.J's Avatar
Originally Posted by Goingfast
Hey
you install the NA blocks in the rear as in the picture and you need to drill only 2 outer holes to mount the new blocks
Marcos.J is offline
Old 06-24-2020, 04:06 PM
  #644
OVA
OVA's Avatar
So Marco
question
Are racing your conversion on Asphalt or carpet track?
OVA is offline
Old 06-24-2020, 04:27 PM
  #645
Super Moderator
Marcos.J's Avatar
So Marco
question
asphalt at the moment will be racing it on carpet in July
Marcos.J is offline
