Like Tree321Likes
Yokomo BD9
Old 09-13-2019, 07:39 AM
  #586
Originally Posted by porsche928gs
Probably the problem is that they put the top deck split on the front instead of the rear like is done traditionally . I believe if they change this it would be much better. In the meantime I think you should try the front stand off screw in with the proper amount of spacers under the top deck. To stiffen the front.
I did use the front stand off but it doesn't help much on the carbon kit. I'm going to try a couple things tonight before my PSM chassis comes in.
DavidNERODease is offline
Old 09-13-2019, 12:42 PM
  #587
The Teacher's Avatar
Trader Rating: 62 (100%+)
DavidNERODease, I have both the BD9 and MTC1 fully optioned out...it's not even close the DB9 out performs the MTC1 on any surface in any class.
Marcos.J and DaSilva3525 like this.
The Teacher is offline
Old 09-13-2019, 02:38 PM
  #588
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
The is the first time I ever heard that.. I am sure you may have a good answer on this one..(Why! )
OVA is offline
Old 09-13-2019, 04:05 PM
  #589
OVA, unfortunately I'm the guy locally who is known to try everything. With the guys I race with locally I know where I should shake out regardless of what car I drive. I ran the MTC1 on both carpet and pavement and could never get it on pace with the guys I normally would run with. The car never seemed to have the steering I needed and seemed to carry little to no corner speed. I spent at least 3 to 4 months running the car trying different things. Now with the Yokomo, not only was I on pace with the normal guys I run with but I'm actually challenging some of the guys I rarely hang with. This was after only a few weeks with the car. So at the very least I feel the car has a wider setup window. In my opinion I feel the MTC1 has weird flex characteristics. I tried all of the different top decks with the different center braces and could never get the car to have steering and rear traction at the same time. The front caster blacks are too soft...even after the update.
DaSilva3525 likes this.
Old 09-13-2019, 04:41 PM
  #590
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 239 (100%+)
pretty much same here the MTC1 was ok outdoors , on black crc carpet it was way off pace
Marcos.J is offline
Old 09-13-2019, 06:30 PM
  #591
STLNLST's Avatar
Trader Rating: 32 (100%+)
Stiil soft..........that's not good!
STLNLST is offline
Old 09-13-2019, 06:58 PM
  #592
OVA
OVA's Avatar
Hey Teacher
I thought you were saying opposite ..Sorry I missed read your post.. I do agreed with your resulted .
OVA is offline
Old 09-15-2019, 07:56 AM
  #593
I've done well with my MTC1 so my expectations are high. If I don't get BD9 like performance out of it this month, it'll be heartbreaking. It's so pretty.
Brian10811 likes this.
Old 09-15-2019, 09:48 AM
  #594
STLNLST's Avatar
So what setup's are people running with the Medius kit? Did you all start off with the same setup and just switch chassis?
STLNLST is offline
Old 09-15-2019, 02:03 PM
  #595
Man with all the hype over the new mid motor conversions I broke down and ordered a Medius kit... Now I have to test the alloy chassis, stiff graphite chassis and the mid motor alloy chassis...all before indoor season starts. If anybody has any good CRC black carpet setups using any of these chassis please post..
Old 09-15-2019, 02:48 PM
  #596
More or less the setup from nationals adjusted slightly. I'm not sure that one is going to be beaten while it's hot. When it cools down we can drop the rollcenters some.
Brian Bosley is offline
Old 09-15-2019, 03:20 PM
  #597
STLNLST's Avatar
cavs setup from the nats? I ran my own setup as I was the only BD9 at the track in spec prior to the nats. The other BD9 owner runs mod.
STLNLST is offline
Old 09-16-2019, 07:22 AM
  #598
mac853's Avatar
Could anyone tell me if BD9 could use Xray T4 19 anti roll bar?
Because i feel Yokomo roll bar quality become badly!
mac853 is offline
Old 09-16-2019, 10:34 PM
  #599
I run it in stock, it's really good if you run Solaris. A flatter tire needs something to exit the corner better
Old 09-23-2019, 12:40 PM
  #600
Default PSM
This PSM chassis is very impressive.
