Like Tree321Likes
Yokomo BD9
Old 07-11-2019, 07:28 AM
  #451
mac853's Avatar
Originally Posted by RC MARKET
What kind of benefits?
More rotation and better weight distribution?
mac853 is offline
Old 07-11-2019, 07:54 AM
  #452
DaSilva3525's Avatar
Seems to be the way TC is going to be going in the future or at least the option. An alum chassis is my most wanted addition to a MM Conversion if anything. I have never driven a MM TC to give details but I would assume more steering, more rotation, some more corner speed.
DaSilva3525 is offline
Old 07-11-2019, 08:10 AM
  #453
Well AMX has been dominating at every event on every surface with mid motor/equal belt length cars for about a year now so conversions are coming out for literally every standard TC in existence. I like it but there are some trade offs in electronics positions (even on the AMX)... Rebellion is claiming to solve these issues and will make conversions for all popular std TC's.
https://www.redrc.net/2019/06/rebell...rsion-teasers/
DavidNERODease is offline
Old 07-11-2019, 08:17 AM
  #454
Yup.. time will tell in the next 4-5 months how many conversion kits and updates we will see. Maybe it's going to be like off road soon where you can buy a Mid or Rear motor car from the factory lol..
I know a few guys at my local track that have 2 or 3 Awx cars in different configs o.O
Old 07-11-2019, 05:33 PM
  #455
Guys, need some help.
I've installed the steering brace/stiffener by RCMAKER & now my steering response is awesome! The problem is now the back side of my kit is loosing grip due to the improve steering response.
What fix can I do on the back side?
airbiscuit is offline
Old 07-11-2019, 05:49 PM
  #456
The Teacher's Avatar
Trader Rating: 62 (100%+)
airbiscuit, where is it loosing grip entry, mid or exit of the corner? I had the same problem with my car once I got it to steer like I like it. Haven't totally solved the problem yet but have made things better by playing with the anti-dive in the front and rear toe. Have played with camber link angles as well but not sure if that's helping or hurting yet.l
The Teacher is offline
Old 07-11-2019, 06:25 PM
  #457
STLNLST's Avatar
Trader Rating: 32 (100%+)
sad thing is our on road cars cost the same as 8th scale off road cars ☹️ By the time you purchase a kit and a conversion kit all you need is your OS engine and you’re nitro ready.....lol None of the Manufacturers of the standard cars are making these kits so I dont expect to see complete kits offered any time soon. I could be wrong though.
STLNLST is offline
Old 07-11-2019, 07:06 PM
  #458
tbrymer's Avatar
The weird thing about the rebellion is that the top plate is so much wider on the battery side of the car. Seems like that would make the front to rear flex different on both sides, by a lot. I'm not sure how, or if, it translates to the track.
tbrymer is offline
Old 07-12-2019, 12:52 AM
  #459
I am loosing grip on mid corner causing my kit to spin out.
Old 07-12-2019, 04:57 AM
  #460
-Drop the rear inner camber link down .5mm to start (More camber gain, higher roll center)
-If you are running the long T plate take out any screws in the rear section of the T plate
-Stiffer rear springs
-Try reducing the rear droop by another .2 (Ex if are 3.0 under the rear arm bridge go 3.2 or 3.3
- Add a hair more front droop like .2 (Ex if you are at 6. under the front arm pin go 5.8
If you are still having some grip issues add a little bit more rear toe.
airbiscuit likes this.
Old 07-12-2019, 09:07 AM
  #461
Trader Rating: 16 (100%+)
Look closely, there is only one side next to the spur gear, that's why it is so wide.
EDIT: I'm guessing they also made it much wider so that in twisting it would approximate the rest of the top plate. Since it's offset, you have to make it wider to have the same torsional stiffness of the rest of the plate.
glennhl is offline
Old 07-12-2019, 11:01 AM
  #462
tbrymer's Avatar
I'm not questioning the torsional flex, just the front to rear. Having the top plate thicker on one side should allow for one side to flex more than the other, which isn't desirable. Pretend you are taking the front of the car and the rear and folding the car in half. The side with the wider top plate will tend not to move and the other side (motor side) will tend to flex easier.
glennhl likes this.
tbrymer is offline
Old 07-12-2019, 04:33 PM
  #463
Thanks! I'll try it out when the time comes.
DaSilva3525 likes this.
Old 07-19-2019, 06:41 AM
  #464
Rebellion mid update - looks really good!
https://www.redrc.net/2019/07/rebell...s-coming-soon/
Tremor24 and Bigiogas32 like this.
Old 07-20-2019, 05:40 AM
  #465
And another...
https://www.redrc.net/2019/07/arrowm...s/#more-172065
Tremor24 likes this.
