Schumacher Eclipse 2 1:12 chassis >
Like Tree144Likes
    Hide Wikipost
Old 09-27-2018, 09:09 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Schumacher Eclipse 2 1:12 chassis
Last edit by: 1/8 IC Fan
Print Wikipost
Old 10-04-2018, 11:21 AM
  #16
TrevCoult's Avatar
Originally Posted by Erhard
What maintainance is needed on the front and how often?
Is the new front still competitive against the old one in open class on bumpy conditions?
BR Erhard
Fill the kingpin with oil from the top screw hole, then the oil will come out of the holes in the side of the kingpin and it will last longer. I'd say check every 3-4 runs.
One of the major test tracks that Schumacher uses is MB Raceway in Leeds which is quite bumpy and it is the track we used on Sunday for the test day. There is no problem at all running the car on a bumpy track with any motor. Try thicker oil than the base setup on the kingpins and centre shock.
TrevCoult is offline
Old 10-04-2018, 12:39 PM
  #17
Now that is a nifty trick!
qcrc and Erhard like this.
DavidNERODease is offline
Old 10-13-2018, 06:25 AM
  #18
Trader Rating: 21 (100%+)
will u7299 (alloy chassis) fit the v2?
TamiyaMatt84 is offline
Old 10-13-2018, 07:09 AM
  #19
The manual says yes (long pivot option only though).
Old 10-14-2018, 02:00 AM
  #20
TrevCoult's Avatar
It is possible to run the short pivot option but only if you are prepared to get your Dremel out.
In my own view the alloy chassis is not necessary as there are plenty of flex adjustments possible with the fixing options for the top deck.
Old 10-14-2018, 08:19 AM
  #21
I'm trying to get this kit through my LHS. This chassis appears to address most of my usual gripes although I'm confused about how pod tweak is addressed - there doesn't appear to be any adjustment in the centre pivot ball mount?
Old 10-15-2018, 06:36 AM
  #22
TrevCoult's Avatar
There is just enough movement between parts so that if you follow the instructions and tighten the pod ball screw last as it says in the instructions it will be correct. It doesn't need any further adjustment. The Atom, Atom CC and Eclipse are all the same, as were the Corally 12SL/12SLX I used to race a few years ago.
If you can't get hold of one in the USA I'd recommend MB Models in the UK, they will ship internationally.
jetnjme and DavidNERODease like this.
Old 10-15-2018, 09:16 AM
  #23
I'm super pumped about this car. I held off on the Eclipse 1 because I wanted a true Schumacher front end and now they've delivered. My LHS in Canada will get it (eventually).
Old 10-15-2018, 12:42 PM
  #24
cementsurfer86's Avatar
David,
If you can't get ahold of one, contact Phil @ discountrcstore.com. He's U.S.-based and I'm sure he'd be happy to bring one in for you.
cementsurfer86 is offline
Old 10-15-2018, 07:34 PM
  #25
A Main hobbies shows the v2 eclipse in stock for $289
vafactor is offline
Old 10-17-2018, 09:56 AM
  #26
Originally Posted by XCELL
I Like the Corally inspired front end, but I wish the would have gone with a traditional rear end.
Patrick
Actually Corally also had a car with a similar rear end back in the mid 90's
cmego is offline
Old 10-17-2018, 10:00 AM
  #27
cmego is offline
Old 10-17-2018, 10:28 AM
  #28
That is cool but totally different.
Old 10-17-2018, 12:45 PM
  #29
Dave it's Kirt from CCR Corally had another one similar to this but closer to the schumacher with a horizontal pin on the axis they replaced it with the ball setup you see above.
cmego is offline
Old 10-17-2018, 12:51 PM
  #30
Dave if you watch the video you'll see witch one I'm talking about I've owned about 5 cars over the years all were good or great except for 1 the anoheimi edition was a turd.The biggest problem with corally was you were stuck using their wheels and tires.
cmego is offline
