Schumacher Eclipse 2 1:12 chassis >
Like Tree144Likes
    Hide Wikipost
Old 09-27-2018, 09:09 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Schumacher Eclipse 2 1:12 chassis
Last edit by: 1/8 IC Fan
Print Wikipost
Old 06-26-2019, 07:46 AM
  #181
No extra shims or screws required - the kit is very complete. It comes with all required tools, lubes and parts for the typical adjustments and the manual has very good tuning tips. You will need to get a Kimbrough Servo saver Servo Savers :: Small Servo Savers - Kimbrough Racing Products - RC Spur Gears, Pinion Gears, Servo Savers specifically for Sanwa (kits includes the Kimbrough Futaba spline version). Schumacher really does a nice job with their kits.
ShadowAu, choisan and Brian10811 like this.
DavidNERODease is offline
Old 07-02-2019, 11:51 PM
  #182
TrevCoult's Avatar
Originally Posted by TrevCoult View Post
One will be available from Schumacher in the next month or two. A prototype was used at the Euros.
The spool axle is now available from Schumacher. It is part number CR721.
qcrc, DavidNERODease and Erhard like this.
TrevCoult is offline
Old 07-03-2019, 07:51 AM
  #183
Ooooo!
choisan, qcrc, Juniorabca and 1 others like this.
Old 07-18-2019, 11:23 PM
  #184
Originally Posted by DavidNERODease View Post
Ooooo!
In the meantime, I just blocked my ball diff to find out benefits.
It really depends on the track. Acceleration and breaking clearly improves. On narrow tracks I found car became harder to control and take advantage of the benefits. The loss of acceleration out of corner with diff is what makes control better.
This refers to a narrow track with some bumps and debris, that puts some unpredictable disturbance to the cars stability. Here the diff seems to give more control,
Best Regards, Erhard
P.S.:
Blocking the diff:
I removed the balls out of spur gear and made the gear thicker with some tape to reach the thickness of the balls.
Of course the spool axle kit may be lighter than a diff, or blocked diff. Possibly the spool also is more stable. We had some broken diff axles. The newer Version was a bit better, but the improvement is moderate. I recommend to keep 1 axle per car in spare, to secure the race weekend.
Erhard is offline
Old 08-08-2019, 09:45 PM
  #185
snopro31's Avatar
Trader Rating: 53 (100%+)
I have a question if you order the car now does it come with the updated front beam?
on crc black carpet is the stock chassis working or is the alloy one needed? if the alloy one is needed is drilling it to have the short set up needed?
snopro31 is offline
Old 08-10-2019, 01:51 AM
  #186
TrevCoult's Avatar
The latest kits do now have the updated front beam. There may be older kits still around though as the change is recent.
I've never run on CRC black, but the team do not use the alloy chassis even on very high grip. If you do want to use the alloy chassis with short pivot yes you will need to machine it to make the pivot hole the same shape, as the alloy chassis was designed for the E1.
Old 08-10-2019, 11:02 PM
  #187
antlockyer's Avatar
Destiny and Yokomo both have damping front ends
antlockyer is offline
Old 08-11-2019, 02:18 AM
  #188
TrevCoult's Avatar
Originally Posted by KIYATSIA View Post
It sacrifices the only state of the art front suspension with defined damping (tubes!) on the market. The damping in the front is actually the only remaining way to basically further improve a PanCar, as it gives better traction and control to the whole car. Everything else was/is already out there from every chassis on the market.
It has a simple but very effective front damping system if you look at the design of the kingpins.
Rick Vessell likes this.
Old 08-13-2019, 05:53 AM
  #189
I do know that a local racer here has been using this car since it came out on CRC Black Carpet with the stock chassis without issues. Car does very well with his setup against all the other manufacturers currently being run in the Alberta clubs. I will hopefully be trying mine out for the first time this coming weekend in Calgary. Only upgrade that I have is the new front beam and changed the rear spring over to a stiffer one than kit.
Jon
Juniorabca is offline
Old 08-13-2019, 07:10 PM
  #190
snopro31's Avatar
Jon
well I will come by your pit in Calgary and and take a better look at the car if you donít mind.
I assume the other person is Patrick is he going to Calgary? Will be strange for me to be at a race with out a 12th
Juniorabca likes this.
snopro31 is offline
Old 08-14-2019, 08:11 AM
  #191
patorz31's Avatar
I may be be racing in Calgary if I get my renovations on the house done in time. The setup on my Eclipse was put on by Jon so talking to him would be a big help. I have the stock chassis on my Eclipse 2 I have one with Aluminium Chassis as well, With 17.5 and the spec tires the aluminium chassis is slower due to the weight of it. The stock chassis with the upper stiffeners make the carbon chassis very stiff and it works well. It's a neat design and I hope they do an F1 chassis someday with the same basic layout.
snopro31 and qcrc like this.
patorz31 is offline
Old 09-08-2019, 05:43 AM
  #192
Hello KIYATSIA,
I had the same thoughts as you one year ago. The Eclipse "One" had a damping system with mini tubes and they were not performing as hoped. Due to the vertical mount, a breathing hole in the dampers was loosing the damping lubricant. I did some modification to this axis to fix this and found perfect damping.
However - finally I changed to the new system for other reasons.
The Eclipse 1 axis is not robust enough. Almost all parts can break in moderate crash and lead to time consuming repairs. In races this was very hectic, with so many super small parts.
In addition, the tyres had really a lot of free play due to all the joints and their bearing play adding up.
Then came the new axis. I tested it and it was a much better package. Ideal!
The free play is really small, so tyres are guided well, leading to driving with precision. Plus, the damping works really good, using some black grease on the Kingpins. Others use silicon as for the tubes. It still is a tube damper, No point, why other dampers based on tube concept should be superior.
In total, the new axis is really competitive and super robust, simple to maintain also.
Best regards, Erhard
Erhard is offline
Old 09-16-2019, 09:05 AM
  #193
Default OMG
I assume the Eclipse will receive the same awesomeness - finally a steel chassis and a bunch of other goodness!
https://www.redrc.net/2019/09/schuma...r/#more-174741
qcrc likes this.
Old 09-16-2019, 06:24 PM
  #194
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
Great news, glad to see they are sticking to their design!
1/8 IC Fan is offline
Old 09-16-2019, 11:25 PM
  #195
TrevCoult's Avatar
I've seen a prototype of the next Eclipse. Though it wasn't the final car I don't think you will be disappointed when it comes out.
ShadowAu, qcrc and DavidNERODease like this.
