Schumacher Eclipse 2 1:12 chassis >
Like Tree144Likes
    Hide Wikipost
Old 09-27-2018, 09:09 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Schumacher Eclipse 2 1:12 chassis
Last edit by: 1/8 IC Fan
Print Wikipost
Old 04-08-2019, 08:39 PM
  #151
c-lyon's Avatar
I have the hollow one from EA motorsports, a bit expensive, but has survived many "incidents".
Erhard likes this.
c-lyon is offline
Old 04-08-2019, 11:27 PM
  #152
TrevCoult's Avatar
Originally Posted by Erhard
Hi,
I would like to try a solid axle in the Eclipse 2. Schumacher seems to have no solid axle. Which alternatives are available? I only found the Roche solid axle kit. Are there others?
One will be available from Schumacher in the next month or two. A prototype was used at the Euros.
DavidNERODease and Erhard like this.
TrevCoult is offline
Old 04-09-2019, 12:10 AM
  #153
Originally Posted by DavidNERODease
An early build pic but you can see the steering stops.
I also found that the inside wheel can jam over by testing. Although it doesn´t seem to happen in real racing, when Orlowsky or Murray drive, it is possible definetly. With my kind of luck it happens to me in racing, i assume.....
My solution was to glue on some bumper rubber on the camber strap. It is still possible to reach the initial wheel stop, but it gives a soft spring force preventing the jammed position to stay. Rubber is only glued by half of the inner length.
BR Erhard
Erhard is offline
Old 05-06-2019, 11:26 AM
  #154
Dang the design of the Eclipse would so be good for an F1 chassis - especially with the new trend of mounting the rear wing to the chassis and the front end design would adapt so easily! I'm still holding out Schumacher!
DavidNERODease is offline
Old 05-06-2019, 07:00 PM
  #155
patorz31's Avatar
I asked, was told there were no plans for one. Going to draw up a chassis and get Bezerk to cut it so I can build one out of one of my spare chassis.
Juniorabca likes this.
patorz31 is offline
Old 05-06-2019, 07:40 PM
  #156
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Have Dragonplate fab up a chassis for you, for whichever F1 front end you chose and the Eclipse rear end.
1/8 IC Fan is offline
Old 05-07-2019, 07:41 AM
  #157
Default F1
It would require quite a bit more than a new main chassis plate... I just find it hard to believe that Schumacher doesn't have an F1 prototype based on the Eclipse out zooming around some somewhere. I want one.
Old 05-07-2019, 10:10 AM
  #158
patorz31's Avatar
As far as I have been told they don't. I want one. I'll build my own if I have to.
patorz31 is offline
Old 05-07-2019, 11:51 AM
  #159
Default Shocking
It's shocking to me. F1 is so popular and they have the perfect rear pod design for F1 - far superior to the current chassis mounted rear wing designs. I'm holding out for a factory Schumacher F1 chassis based on the Eclipse. Some designer at Schumacher is having a chuckle right now as he drives a pre-production prototype around his kitchen floor as we speak - I just know it. Has to be.
Old 05-07-2019, 12:02 PM
  #160
I'm calling it the Shadow... although Eclipse F would be acceptable.
aracefan likes this.
Old 05-08-2019, 03:18 AM
  #161
antlockyer's Avatar
F1 is pretty much dead over here.
antlockyer is offline
Old 05-08-2019, 06:56 AM
  #162
It's because Schumacher doesn't make an F1
Old 05-08-2019, 08:57 PM
  #163
Make two of them.. One for you and the other for me.. LOL..
Juniorabca is offline
Old 05-09-2019, 01:57 AM
  #164
antlockyer's Avatar
It's because they are awful in UK conditions. I'd have to be paid a lot to race one lol
Old 05-09-2019, 04:59 AM
  #165
It is amazing to see those words when this year the indoor national have had their best attendance in the last 3 years.
The outdoor series was full in the first meeting and we are way better on attendance than the previous 3 years.
It is not a big market in the UK, that is the truth, but it is not dead.
Regarding that they are draedfull to drive, first of all, it is a RWD car with rubber tyres, so it is not going to be easy, that is aprt of its fun. If you want an easy class, you now, TC 21.5 blinky is ideal for you. The current spec tyres make a fairly decent behavior outdoors and the indoor ones were really good last winter.
By the way, Andy Murray, Schumacher driver, has been playing up with F1 prototypes the last few years, but as the market is not big enough it looks like they will not move on.
Cheers
Javier
jimjav is offline
