Rc car has very laggy connection >
Old 09-22-2018, 05:49 AM
Default Rc car has very laggy connection
My maverick strada dc is completely stock. It worked 2 runs nut the third it was wet outside. I thougt nothing of it since it sais that it is water proof on the box.
but then while driving it just stopped working. I kept pressing the gas and brake but nothing was happening. Then it started working again for half a second then stopped.
I took it home and cleaned it dried it and then it started working like normaly. I took it out again amd drove it a few meters only for the same laggy connection to occour.
i took it in again and rebinded it and tried but the smae thing happens.
If it standing still i turn and a second later it turns but then it goes back before i stop turning on the controller. If i hold the gas it just sort of jumps forward and then stops for a few seconds and then responds a bit only to stop where its at and not do anything.
any idea why?
VeXh is offline
Old 09-22-2018, 08:27 AM
sosidge's Avatar
Make sure the battery is fully charged and make sure the car's electrics are as dry as you can get them - strip it down as much as you can and put it in the airing cupboard or over a warm radiator for as long as possible to get any lingering moisture out.
sosidge is offline
