CRC F1 setup help >
CRC F1 setup help
Like Tree4Likes
  • 1 Post By BullFrog
  • 1 Post By robk
  • 2 Post By old_dude
CRC F1 setup help
Old 09-19-2018, 09:49 PM
Default CRC F1 setup help
looking for help on the setup for my
CRC WTF1-FC16
bouncermike87s is offline
Old 09-20-2018, 08:32 AM
What would you like to know?
1) battery tranverse
BullFrog is offline
Old 09-20-2018, 11:34 AM
Moogumby's Avatar
Trader Rating: 32 (100%+)
While no OP, I would be looking for set ups for CRC Black Carpet, medium size track.
Moogumby is offline
Old 09-20-2018, 02:52 PM
all I run is on crc black carpet. 45 front springs kit sides. battery transverse. extra weight on the front lower arm. I also use the new derlin upper front arms. ESC - HW stock spec. With this esc you can fine adjust the brakes.
Moogumby likes this.
BullFrog is offline
Old 09-20-2018, 09:07 PM
ride heights? front caster?camber?
Old 09-21-2018, 07:52 AM
ride height 4.25 front and 6-6.5 rear. caster is like the direction show. And camber for me is 1 1/2 . I have something for caster coming soon to try. If you have a hobby shop that sell Rage parts #RGRC105/3979206664) front hinge pin set. Just use the long ones. They were 5 dollars at my HS..They replace and fit perfectly.
BullFrog is offline
Old 09-21-2018, 08:02 AM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
I think he (the OP) would like some editable Setup Sheets, and also some team driver ones as well for reference.
1/8 IC Fan is offline
Old 09-21-2018, 09:29 AM
robk's Avatar
Trader Rating: 22 (100%+)
There is no setup sheet. At least i haven't seen one
robk is offline
Old 09-21-2018, 09:38 AM
robk's Avatar
Better yet, what exactly is the track surface, bite level, etc? That would make it easy to help
scirocco14 likes this.
robk is offline
Old 09-21-2018, 10:52 AM
scirocco14's Avatar
I would say the kit setup will get you 98% of the way there on the CRC black carpet. Set the ride heights so that it doesn't scrub the carpet (4mm would be a good start) and see what it does. Front camber, I'd suggest -2. A little front toe-out to stabilize it on the straights.
On asphalt, a little less front camber, and a softer rear center spring. That worked for me.
Tires are going to be the biggest factor on how well it handles, IMHO.
Mark
scirocco14 is offline
Old 09-21-2018, 12:48 PM
There is no set-up sheet. As for what I've said This is from (ride height) CRC and rest is from several of us CRC drivers here in Florida. I know this set-up I posted works on our cars on Black carpet here .
BullFrog is offline
Old 09-25-2018, 05:56 AM
I'll give everyone what I just used to finish second at the USVTA Southern Nationals at Apex Raceway.
.45 springs all around (kit)
white center spring with 25 w in the center
1 degree of camber
1 degree toe out
0 caster (all shims in front)
4.5 mm ride height front and rear
1 mm rear droop
2 mm front droop
battery inline and full back
tires were the gravity premounts as handouts
sidewall glue just below the crown on the fronts
SXT regular full rear, 7/8 front inside out
Xray gear diff with 15k ( many run much stiffer but I like this weight)
I qualified 5th and with luck and mostly clean driving I finished second.
I dont have the skills of John Barron II (Winner and congratulations to him) but I am also 67 years old
robk and iTz Nicholas72 like this.
old_dude is offline
Old 09-25-2018, 05:00 PM
robk's Avatar
Shows that a standard setup works very well with this car
robk is offline
Old 09-26-2018, 05:58 AM
I will add that this car has been out for awhile where other manufacturers have released several models. It is still fast and very tuneable. I am not a spring chicken but I know what changes will do to this car so I don't get surprised when I get on a new layout or surface ( even black carpet varies ) .
ROBK, I want to add a thank you for pulling F1 under the USVTA banner. I believe that is what has helped it start to grow again.
old_dude is offline
