Convert 4WD to FWD >
Convert 4WD to FWD
Like Tree17Likes
Convert 4WD to FWD
Old 09-18-2018, 05:30 AM
Shop Owner
nnick's Avatar
Default Convert 4WD to FWD
Recently there is hype with FWD cars and many have already bought one to race and have fun. As, at the moment, I won't to purchase a FWD kit BUT I have 2 4WD that I don't use it. What can I do to make it competitive against the normal FWD cars?
I'll remove rear diff, add weight at the front as much as possible, anything else?
nnick is offline
Old 09-18-2018, 06:00 AM
moparSRT's Avatar
If you want to be competitive with other fwd cars then that is what you will need ... a fwd car, you will never get enough weight in the front with that 4wd
moparSRT is offline
Old 09-18-2018, 06:05 AM
Shop Owner
nnick's Avatar
well, yes that is obvious
Apart the two things I mentioned is there anything else I can do?
nnick is offline
Old 09-18-2018, 07:09 AM
This is where we get creative. Hah!
What car do you have? Several tamiya cars let you move the motor, and such forward in the chassis.
Use the biggest gear combination you can, to move the motor forward.
Use a small battery, mount it forward.
Move your ESC forward, mount it on the front bumper. Mount it on the steering servo. Move your reciever forward.
I think... that's most of what you could do. Without drilling holes, buying belts, and getting into month long ordering of parts.
Billy Kelly likes this.
Nerobro is offline
Old 09-18-2018, 07:28 AM
Colbynobo's Avatar
Trader Rating: 21 (100%+)
I had a Yokomo BD7 that I briefly tried running as FWD. I swapped the spool and differential around so that the spool was in the back and the differential was in the front, removed the rear drive belt and gave it a go. I was attempting to run it primarily in a dusty parking garage, so it wasn't in the most ideal conditions. I had to put a lot of extra weight up front to make it somewhat possible to drive. I even tried running wider, VTA rear tires in the front with VTA front tires in the back. It wasn't pretty and still had a lot of understeer in the corners. I eventually gave up.
Colbynobo is offline
Old 09-18-2018, 07:54 AM
You will have better luck and more fun making it RWD. Touring cars have a weight bias towards the rear by default due to the wing. I found it to be very fun to run RWD with my old Xray on carpet. I mounted the battery transverse and to the other side. I ran the same tires (sorex) front and rear with very soft springs.
moparSRT likes this.
MatsNorway is offline
Old 09-18-2018, 06:07 PM
Trader Rating: 6 (88%+)
if you convert awesomatix A700 to fwd you will probably outperforms all FWD chassi on the market but its more a cheater car because you dont have the motor at the front like a real FF FWD chassi
Quinny45 is offline
Old 09-18-2018, 06:12 PM
Speed Chaser's Avatar
I highly doubt that and would actually love to see that thing go up against a modern fwd chassis. Having the motor upfront actually work in favour of an fwd platform not against it in rc scale
moparSRT and gigaplex like this.
Speed Chaser is offline
Old 09-18-2018, 08:14 PM
Billy Kelly's Avatar
I’ve finished a race or two with a broken rear belt. Basically running as FWD. I’d guess 2.5-3 seconds a lap slower. Acceleration was gone. Had to try to limit brake use as much as possible Now following your ideas. Diff to front, let rear just spin free. Lots of practice I’m sure it could work. It’s the being competitive part that I doubt.
Billy Kelly is offline
Old 09-18-2018, 09:44 PM
gigaplex's Avatar
Why would you leave the spool in the rear when disconnecting the rear belt? That'll cause some weird cornering issues.
MatsNorway likes this.
gigaplex is offline
Old 09-18-2018, 10:17 PM
...but its more a cheater car because you dont have the motor at the front like a real FF FWD chassi
There are no real FWD with engine behind front axle?
I know only one racing prototype (not based on production car) with FWD - and it has engine behind front axle
https://en.m.wikipedia.org/wiki/Nissan_GT-R_LM_Nismo
Papi is offline
Old 09-18-2018, 10:28 PM
There is a lot more car than just the Nissan lm prototype that has a front mid-engine aka behind the front axle. I used to own one aka the honda s2000 but there are many others.
Aston Martin Vanquish and V8 Vantage 2005, Chevrolet Corvette, Dodge Viper, Ferrari 612 Scaglietti, Maserati Quattroporte, Mazda RX-7 and RX-8, Mercedes-Benz SLR McLaren, BMW Z4, Nissan 350Z
Old 09-18-2018, 10:37 PM
fyrstormer's Avatar
The wing merely counteracts the lift generated by the downward slope of the body shell's rear surface, whereas the body shell's front surface generates downforce naturally and doesn't need a wing. If you have an extremely aggressive rear wing, it might cause the car to generate slightly more net downforce in the rear, but it still won't change the car's center of rotation. The center of rotation is biased towards the rear of most touring cars because most of the heavy components are located on the rear half of the chassis.
Anyway, to answer the OP's question, unless they can move the motor ahead of the front diff and move the battery just behind the front diff, the car will never be competitive due to poor traction at the front wheels. Just for fun they could stack a bunch of lead weights ahead of the front diff to change the center of mass closer to what a dedicated FWD car has, but the extra weight will obviously make the car uncompetitive. So basically, if the car needs to be competitive, you have to buy a dedicated FWD chassis, or else fabricate your own custom motor mount and battery tie-downs. But if you just want to have a little more fun with a car you're bored with before you sell it, just stack a bunch of lead weights ahead of the front diff.
fyrstormer is offline
Old 09-18-2018, 10:42 PM
Since when is Honda S2000 FWD or racing prototype?
it's true that MFF layout is not used nowadays, but in past there were many cars with this layout. Many models by Citroen an Renault, for example.
Papi is offline
Old 09-18-2018, 10:45 PM
OH I miss understood your statement then since the Nissan prototype also power its rear wheels I thought you were including RWD cars to
