Old 02-19-2006, 01:33 PM   #1
Default Kick up?
Hi
By running the front pivot block lower than the front rear pivot block what efect will it have on the car?
Cheers
Xrayskid is offline   Reply With Quote
Old 02-19-2006, 02:58 PM   #2
polesitter61's Avatar
Usually will make the car a bit tighter when entering the corner, it won't let the weight transfer to the front of the car as quickly
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 02-19-2006, 07:12 PM   #3
Rick Worth's Avatar
Kick up is when the front block is higher then the rear. When the rear is higher it is anti dive.
Rick Worth is offline   Reply With Quote
Old 02-19-2006, 07:31 PM   #4
Trader Rating: 19 (100%+)
Makes more steering, and also makes the steering a little more agressive into the corner. Gotta look at it this way, the hingepin is angled down at the front and higher in the rear, so you're taking away caster.
Zaner24 is offline   Reply With Quote
Old 02-19-2006, 07:41 PM   #5
Actually Zaner it's the opposite, it's almost like running a stiffer spring in the front end, but doing it with the geometry instead of spring rate. It will make the car more stable on entry because the weight transfer is slowed down.
www.slickzero.com
Old 02-19-2006, 10:07 PM   #6
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Wouldn't that be like thickening the dampening not the spring tension?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-19-2006, 10:10 PM   #7
Andrew Gray's Avatar
Front kick-up generally makes the car easier to drive, especially on bumpy tracks, and will give more steering entering a turn. However, you will loose on-power (exit) steering.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 02-19-2006, 10:34 PM   #8
zipp's Avatar
so kick-up is also known as pro-dive??
if that's so, then kick-up would increase front traction into the corner, and enable tighter turns, much like running softer springs in the front, is that right?
never really got this right..
zipp is offline   Reply With Quote
Old 02-20-2006, 06:09 AM   #9
Slot - you are right, it would be more like running a thicker shock oil than a stiffer spring. The problem with this thread is the termanology (spell?) that is being used. The original poster said he was running kick up, but the way he explains the pin holders locations is actually "anti-dive". Anti meaning that the suspension is resisting the weight transfer.....basically Anti-weight transfer. If you check out the Team Xray forum at www.teamxray.com there is a really in depth article about this topic with everything you need to know for the front and rear of the car.
www.slickzero.com
Old 02-20-2006, 08:14 AM   #10
teamgp's Avatar
There is a good explanation of anti-dive and pro-dive (kickup) in the New XRAY T2 Setup Book that can be applied to any RC car. It contains an updated version of the article on the XRAY forum.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-20-2006, 08:18 AM   #11
teamgp's Avatar
Correct. It also increases overall caster which improves corner exit steering.
Guy Hood
My kick azz Savage arisking Monster Trucks 14 06-25-2007 07:17 AM
LOOKING FOR A KICK A$$ BUGGY RED-LINE M03 R/C Items: Wanted to Buy 4 12-28-2005 07:20 PM
Kick ass sale again! FRP R/C Items: For Sale/Trade 0 08-05-2004 11:34 AM
RC Kick A$$ Sale FRP R/C Items: For Sale/Trade 0 07-23-2004 01:53 PM
HPI RS42 Still KICK ASS ! kilokhan Nitro On-Road 15 02-07-2003 09:59 PM
