Old 02-19-2006, 12:10 PM   #1
Default Removing Slop
Anyone out there have any little tip and trick for trying to get slop out of suspension components, steering components, etc. Do some people even like some slop in there car? Any tricks besides just shimming it out? What do the pro's do(just run new parts?)?
automator is offline   Reply With Quote
Old 02-19-2006, 12:44 PM   #2
MrUnlimited's Avatar
Does the suspension wear out? In that case you should replace the components.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 02-19-2006, 12:50 PM   #3
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default off subject
I
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-19-2006, 01:28 PM   #4
RobertV's Avatar
Thats disgusting. Its even worse then
YOUR OVERSIZED AND ANNOYING COLORED LETTER SIGNATURE.
RobertV is offline   Reply With Quote
Old 02-19-2006, 01:43 PM   #5
howard hudson's Avatar
R/C Tech Charter Subscriber
very informative indeed
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-19-2006, 01:46 PM   #6
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Teflon motor shims can be used to tighten up some of the spaces. Sometimes you just need to play with them to tighten up slop. Otherwise if they are overly worn out, the only option may be to replace the item depending on the parts.
Slotmachine - Thanks for that helpful information.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-19-2006, 08:29 PM   #7
TEM
TEM's Avatar
Some cars can tolerate more slop than others. But the least slop the better.. Mama used to say, "Slop is the devil!". If theres play in the ball cup and ball studs, you can either replace the ball cups with RPM ones which are usually better than the ones the cars come with. If the cups are new but they have slop(sometimes happen), you can do the q-tip CA method which involves coating the inside of the ball cup with layers of CA till there is no slop. If the ball cup is too tight on the other hand, you can pinch them with a pair of pliers while it's on the ball end and then pop them on/off a few time and they get looser.
A lot of steering play/slop is not in the steering mechanism itself (ie the bell cranks, linkages and such), but rather it comes from sloppy suspension components - slop between any pivoting joints like the arms on the pin mounts or the slop between the hub and arm, king pin slop between the hub and knuckles, etc. You can get rid of this slop with the use of thin shims, and sometimes filing the part flat then putting in shims. Teflon shims are smoother but wear out quickly if they are thin. Sometimes I use brass motor shims and either file the shim or arm down so it fits perfectly without being too tight or too sloppy.
TEM is offline   Reply With Quote
Old 02-19-2006, 09:49 PM   #8
To each his own...............
WHAT'S SLOP??? freestyles Nitro On-Road 10 06-21-2008 08:13 AM
Revo rod end slop Warhawk 1 Monster Trucks 3 04-29-2007 10:03 PM
Servo slop TRFTIM Electric On-Road 0 12-24-2006 09:39 AM
Slop in XXX-S steering Aprather24 Electric On-Road 5 08-09-2004 06:26 AM
slop wahturi Nitro On-Road 9 01-06-2003 07:50 AM
